Hey guys,
I am trying to find out what injectors are in my 33, rb25det
I have only pulled off the cap and checked the part number and can't find anything on the net that has the same number, trying to avoid pulling them out and getting them tested.
They are a maroon/ terracotta/ red colour.
The number on them is: A46 - Z00 0127726.
If anyone knows what they are or where I can find out please let me know.
https://www.sau.com.au/forums/topic/396367-injector-identification/
from what I have been reading the 740's are A46 -Z00 0128911. But then looking at some pictures of some for sale the numbers stamped on the injectors are different from that. Is that the case are they still 740's?
the last part of that number is probably just batch or serial numbers, they're never exactly the same.
surely you know roughly what they flow from injector duty and power? what ecu do you have?
Oh yeah, of course he is running NA injectors in his 25DET.... :rolleyes:
I have seen boxloads of NA injectors and they vary in colour from red red to browny red so no points there sorry bud..
Nismos are considered to be just RED...
While the brownish red 480cc were mainly found in the S15 "R-spec" only, they were also available in the Autech S14... :nyaanyaa:
  • 1 year later...
Sorry to dig this up but didn't want to create another thread..
I have light blue injectors. I was told they are 550cc and only marking on it is "Annam" or "Ammam" and couldn't find anything on google about it.. But then again it could say something slightly different but I couldn't tell.. :/
Cheers guys!
Pictures would be a huge help.
Yeah, sorry the car is in Brisbane and I live on the Gold Coast.
I can get some pictures this Saturday/Sunday and will post them up...
Just thought it was a little weird that I couldn't find anything AT ALL on google. :/
Cheers Zane.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
