Hey guys,
New to the Skyline scene
i have 2 quick questions for your neo rb25det Gurus
1) I was told that by blocking the little hole on the inside of the stock BOV that it will increase performance and induce a louder spool and release effect.
Is this true or false
2) What does that lttle hole do, im no expert but it looks like some sort of pressure regulator or something,,
Please see attached.
Thanks Gents.
https://www.sau.com.au/forums/topic/396389-r34-gtt-stock-bov-question/
What more is there to say? Its a simple air valve.
Tap an m5 thread into the hole, loctite a grub screw in there and try it out. If you dont like the way it drives, remove the grub screw.
How it feels on throttle closing will change depending on the tune. Boost may raise a little with no bleeding but as for gains, perhaps at 20+psi?
False, who ever told you that probably read that rubbish off nissansilvia. On throttle the BOV will shut
All it does as scotty nm35 said is bypass air, it aids in making the piston of the BOV move up and down more gently improving driveability.
If you're car is stock, or running the stock turbo, stock boost etc.. don't bother doing anything to it. People say these BOVs leak, I ran 1.4bar through my old car and the BOV held it fine, although I ended up blanking the BOV off totally LOL
It recirculates air back into the intake post AFM. So leaking is probably not the best word to describe what it is doing.
Leave it alone, drive be happy OR do what Scotty said by tapping and installing a grub screw. Either way it will make two parts of bugger all difference to performance.
it is there for a reason. Nissan put it there after spending millions in research.
I do not know why the first thing people have to f**k with is the BOV.
Leave the BOV alone. Get yourself a panel filter and an exhaust, and eventually a front mount intercooler.
"Blocking a hole" isn't going to magically get you some horsepower and make the car run better otherwise nissan would have done it.
@ the Mafia
Totally agree bro. was thinking in that direction, my car is completely stock fresh import and i wouldnt want to f**k with it at all
Cheers
Best mod you can do, put an full turbo back exhaust on it, then a FMIC, then a boost controller, then be happy with it.... till you get silly......then pour stupid amounts of money into it... then once you regain some form of sanity you sell it.... once you miss it, you'll buy another one and it all starts again till your partner tells you off :domokun:
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
