Hey ail just wondering if anyone else has has spark related issues when running a haltech. Yesterday we tried tuning my car which has new plugs and brand new spitfires and it didn't matter how we gapped the plugs or set the dwell we had a major miss at anything over 12 psi and 4000 rpm
https://www.sau.com.au/forums/topic/396398-spark-issues-and-haltech/
You have a neo engine? A lot of aftermarket ecus have problems at the upper end apparently caused by the R34 CAS. Is yours still stock in this area? There are a number of solutions - Ross make one I don't know if Unigroup has another - in NZ a few tuners have developed their own triggering systems for the R34.
Try turning of all acceleration enrichment as well. Have you check that you have proper timing control throughout the entire rev range. Set the timing at 20deg check it all the way to 7000 on a static rev and make sure it's rock solid then do the same with 40degrees.
Ps isn't the r34 signal a 360deg signal and a 654321 narrowing signal? I'm not aware of any differences between r32 to r34 in terms of signals it's just the wiring at the cas is reversed.
cant believe no one has concrete info on this.. haltech dont want to acknowledge a fault.. thing is im wondering if spitfires just cant handle running in wasted spark.
got a new MSD set up now.. spark is huge at idle.. should be interesting to see how it goes now
I can't recall running those coils in wasted spark configuration. But Holden seem to run a single coil v8 to 6200rpm no problem with a coil that takes simulate dwell =2.5 ms.
At 4000 rpm in wasted spark with 2.5ms dwell time your only at 16% duty as in on time of 2.5 off time off time 12.5ms - hardly working a coil IMO.
My bet is still the haltech.
Edited by rob82
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
