Hey ail just wondering if anyone else has has spark related issues when running a haltech. Yesterday we tried tuning my car which has new plugs and brand new spitfires and it didn't matter how we gapped the plugs or set the dwell we had a major miss at anything over 12 psi and 4000 rpm
https://www.sau.com.au/forums/topic/396398-spark-issues-and-haltech/
You have a neo engine? A lot of aftermarket ecus have problems at the upper end apparently caused by the R34 CAS. Is yours still stock in this area? There are a number of solutions - Ross make one I don't know if Unigroup has another - in NZ a few tuners have developed their own triggering systems for the R34.
Try turning of all acceleration enrichment as well. Have you check that you have proper timing control throughout the entire rev range. Set the timing at 20deg check it all the way to 7000 on a static rev and make sure it's rock solid then do the same with 40degrees.
Ps isn't the r34 signal a 360deg signal and a 654321 narrowing signal? I'm not aware of any differences between r32 to r34 in terms of signals it's just the wiring at the cas is reversed.
cant believe no one has concrete info on this.. haltech dont want to acknowledge a fault.. thing is im wondering if spitfires just cant handle running in wasted spark.
got a new MSD set up now.. spark is huge at idle.. should be interesting to see how it goes now
I can't recall running those coils in wasted spark configuration. But Holden seem to run a single coil v8 to 6200rpm no problem with a coil that takes simulate dwell =2.5 ms.
At 4000 rpm in wasted spark with 2.5ms dwell time your only at 16% duty as in on time of 2.5 off time off time 12.5ms - hardly working a coil IMO.
My bet is still the haltech.
Edited by rob82
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
