i have been running wasted spark on a set of splitfires for about 5 years now. The coils will have NO issues in wasted.
turn logging on, and log it when it misses, you might be getting some bogus rpm signals, this is because the 360 optical sensor is really hard for the ecu to cope with especially in a modified engine, i found that cars with modded heads, springs and cams have more issues with this then stock head setups.
check the rpm signal, see if its stable, hold the rpm at one speed and then see if it goes up and goes down in the log, make a log when the car misses, is the rpm jumping over the rev limiter? or is it moving about strangly?
You may need to contact autronic, buy a trigger disk for nissan optical sensors and install it, I have done this to 3 cars in the last 2 months to fix the same issues, the issue is not haltech specific its the fault of the 360 slot hall setup.
the trigger disc should cost about $100 or so, i had to put one in my RB30DET after i changed the cams, before the cams i had no issues...
yeah did all the logging, not a single problem spotted, the miss counter shows a nice stable rpm.
anyway the problem was found in the end. would you believe it was something as simple as sparkplugs. I had 6 brand new NGK plugs in there and 3 of them proved to be faulty in such a way they wouldnt spark correctly, irrespective of what coils used.
not really the word i'd use for it... more like waste of f**king time... so much dyno time wasted chasing issues... guess it comes down to never assume that just because a spark plug is new that it will spark correctly
Can't say that I've ever come across an issue with spark plugs being bad out of the box. The majority of case I've seen is usually due to improper installation - not saying that's the issue here I've just never seen it myself and when you've changed thousands of plugs on high performance engines I would think that's a pretty good sample.
i havent come across it either. im a mechanic and have changed my fair share of plugs. these were brand new and out of the box failed to work. im not sure how but i chucked some 2nd handies in that had been sitting in a pile of crap. blew em off with an air gun and boom, car runs on 6 all the way thro the rpm range.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
