Nistuned Z32Ecu For R33 Gtst
Plugged in my nistuned z32 ecu today which i got from Matt at nistune and the car seems to fine with it in, but the exhaust temp light on the dash is on as soon as the car is turned on.
I have a 96 gtst that I always thought was a series 2 which meant I didnt have to worry about the FICD pin on the z32 ecu being different to the s2 rb25det ecu.
Taken from the nistune website:
5) FICD output – pin 33
* Series 1 R33 only
The R33 Series 1 RB25 engine uses pin 33 for the Exhaust Overtemp Lamp on the dash.This line should be disconnected as the Z32 uses this line to drive the FICD (Fast Idle Control Device) – for idle up when aircon is on. FICD is driven seperately on the R33 Series 1 RB25 via the aircon system. Note that the R33 Series 2 RB25 does use the FICD the same as the Z32 ECU, so this modification is not required for those engines
Anyone know what might be causing the exhaust temp lamp to be coming on or If there was some series 1.5 r33's that run the series 1 ecu but have series 2 bodies etc produced in early 96 or something?
Is there anyway to tell whether its a series 1 or 2 ecu with the serial numbers on the ecu?
  • Replies 66
Posted Images
Are u sure ur car isnt a series 1.5. R33 are tricky when it comes to z32 ecu.
Will be easy enough to sort out mitcho.
Does the car drive or is it in limp mode?
Seems to drive fine, I took it around the block and it didnt die on me or anything, but that was only a quick spin so im not sure.
How can i tell for certain what series it is? Certainly has the series 2 front bar and rear wing and a passenger side airbag that much I know...
Edited by Mitcho_7
Does it have another check engine light? On R32 the exhaust (catalyst) overtemp light is the check engine light. When it is on 100%, it is the ECU advising that there is a fualt code to be read.
Mine is on right now because the Neo ECU and engine are happy, but they're not happy that the traction control stuff is not present. Connect with Nistune, can see exactly those fault codes.
You might have a sensor fault or something rasing a code.
Yeh above the cat temp light is the check engine light which isnt on.
For the time being i have dissconnect the z32 and put my r33 ecu back in, but I still want to get it sorted. I have contacted matt at nistune and he has said it seems unusual, especially if my car is a series 2 as I thought.
From what I understand only 95 R33's are S1.5, anything 96 onwards is a series 2. The S1.5 had a series 2 engine. Im about to put a z32 nistune on my S1.5, hope I dont have this issue.
Correct.
don't worry about that light it should only read a resistance value from the sensor, I haven't seen it effect anything, didnt log codes or jump maps so I just cut the sensor out and disconnected it under the passenger seat, and i didnt get the light anymore, the only thing you should note is whether you have an igniter on top of the motor, if you do series 1 if not series 2 running gear
I didnt even know I had an exhaust temp warning light.... hey wait whats this wire hanging underneath my car... snip, there we go, doesnt seem to worry me now..
try it, its fun...
So u have had the same issue with yours?
There is different ecu mods for each model. And Matt would have modded it to series 2 as u told him.
Few Q's.
Have u tried the A/C to see if the engine idles up?
Is there an ignitor on top of motor at the back?
Yeh, I tried the a/c with the z32 plugged in but because it was cold, it was idling fairly high anyway. The car didn't die went I put on the a/c. If its a series one, the ficd is done by the a/c separately isn't it so shouldnt it work regardless?
I'll go have a look for the igniter on the engine and get a pic now.
 Share
    • Seatbelt bolts are 7/16 UNF in most cases
    • Yes, this is why I end up being 'vocal' with executives. "I want it" can't be "Just because we should have it" you need reasons. It has way too big knock on effects to simply want something "Just because" at that level in orgs with 10,000+ employees. Currently, message labelling. Sounds great. Except there is no governance on how to actually HANDLE message labels, so I may as well implement the labels as "Pink Flamingo" or "Conrod" or "Massive Dildo" and force people to choose one for every message, with no framework underpinning any of it. It has no value and can actually have detrimental value if all it does is serve to annoy people into clicking something random, or just using the default for everything, especially if there's no repercussions for getting it wrong, no monitoring for people doing it right, and no guidance on what needs to be what label. "But we need message labels!" f**k sake.
    • It's worse than that. They cannot even picture the full scope of what it is that they are pitching or wanting. They see the core idea and cannot conceive of any of the side effects, compromises, losses of existing functionality that needs to be replaced somehow, etc etc, that come with doing these things. So how can they do a cost/benefit when they don't even know what the full set of changes actually looks like?
    • I mean something people seem to be WOEFUL at is doing a proper cost/benefit analysis. Going cloud is great, if it saves you time and money. Does it? I have found a LOT of managers just want 'the new thing' with SUB-zero understanding of what it is and how it functions and why they need it. I spend a lot of time on that point nowadays too.
    • I'm an engineer. I am not supposed to do IT. I have been doing my company's IT for 25 years, because initially there was no one else capable and since because I don't trust anyone. Back in the day, we used to run a Linux server with just sendmail level mail handling. Everything was POP and SMTP. Then, someone demanded calendaring and the like, so I implemented Scalix (an OS Exchange clone) - from scratch. Migrated all the numpties over, administered that system for years. Then Scalix started to decline. So I spun up a full Zimbra system. Same same as Scalix, but different (ie, not even a fork). Ran that for a while in parallel with Scalix as I tried to migrate old users over. Both of these were on prem, with local backup in the case of Zimbra. (No backup at all on the Scalix server! Gasp!) At some point, I spat the dummy, after years of this, and capitulated and bought O365 for the whole company and migrated everyone off the on prem stuff and shuffled them off to the cloud. It has been easier and shitter ever since, seeing as MS cannot leave anything alone for more than 3 minutes and have to keep changing everything and making it "better' (I read that as "harder"!). It's like their entire crew are ADHD squirrels on meth. Meanwhile, all our data has been kept on prem on file servers with decent backup. Now the higher ups are demanding that we migrate all the data to the cloud. I am shuddering at the idea that it will all be held to ransom on some shit AWS or, even worse, Azure/Sharepoint system where you're at the mercies of the above posted price hikes, commercial disputes, company collapses/takeovers/DOS attacks/etc etc. I hate it. But... if it can get me free of the bloody IT shit so I can finally concentrate on real engineering work for the first time in 25 years, then.... good?
