  • Replies 66
Posted Images
It's not about the input, it's the output (of the Z32 ECU) that makes the light stay on!
The Z32 has no EHG sensor, nor does it have an EHG warning light.
So if you disconnect the EHG sensor it does do nothing at all (except wasting your time);)
Again:Are you absolutely sure the revs drop now (after Matt sent back the ECU) when you engage the AC?
Just tried the z32 ecu with the exhaust temp unplugged under the passenger seat. No dice, still got the light on the dash.
yeh, what you say makes sense , but I figured it would be worth a try.
And yes the revs drop as soon as the a/c is put on at idle.
Hmmm,
Fair enough, it does not hurt trying (also educational) :)
I am slightly puzzled about the revs now dropping.
All what Matt did was disconnecting PIN33 (on the Z32 ECU) and that PIN33 has no connection whatsoever to the fast idle circuit.
Something does not add up.
If all fails Matt has to undo whatever he did, and you would have to remove the bulb in the dash.
Just closing this thread out. Factory service manual has the S1 pinouts, but later in the workshop manual it discusses FICD and TPS which are series 2 specific. This means there were updates to the manual by Nissan which are internally contradictory because the manual does not clearly differentiate S1 and S2 changes.
Also contrary to the manual Pin 33 remains the exhaust temp lamp on S2 (not Pin 32 which must be a typo). So this line gets cut, the fuel temp line going to it gets a dropping resistor to remove the fuel pump temp DTC error. FICD needs to be routed from the FICD driver IC to Pin 36. Documents to cover internal S2 modifications updated accordingly
http://nistune.com/docs/Z32_ECU_Modifications_Direct_R33_Plugin%20V7.pdf
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
