take the fuel inlet hose off the engine. turn the car on and see if fuel comes out. also how sure are you there is fuel in the car. i work for racv and you would be supprised by the amount of times we have gone out to a car that the customer thought the fuel pump had died and.the swear they only.just put fuel in it only to get it back to the shop, pull out the pump and find an empty tank. next thing would be to check you afm. im sure someone on here could provide you with the voltages at the plug or if you know some with the same car see if you can borrow it
https://www.sau.com.au/forums/topic/396433-not-running/#findComment-6304078
sorry for the lack of info
soooooo got some tools and done some basic tests..
fuel ok
fuel pressure ok
injector pulse ok
spark ok
even got the injectors flowed and tested just to make sure the wernt blocked
checked to see if the cat had failed and was blocking
problem is still occuring which leads me to belive its an electical problem
any ideas??
if it was the maf it would still run with a lilimt of 2500rpm becoz its in safty mode??
Edited by Benny123r33
https://www.sau.com.au/forums/topic/396433-not-running/#findComment-6310461
an
fuel ok
fuel pressure ok
injector pulse ok
spark ok
any ideas??
https://www.sau.com.au/forums/topic/396433-not-running/#findComment-6310471
an
fuel ok
fuel pressure ok
injector pulse ok
spark ok
any ideas??
Unplug the afm and start the car. Doubt it's the problem though.
https://www.sau.com.au/forums/topic/396433-not-running/#findComment-6310592
  • 3 weeks later...
Get a stand alone ecu.
None of this piggy back bs
bingo.
So, the usual advice. Do some research on who are the tuners in your area (you dont want to drive 2hrs + just to drop a car off for tuning of if any troubleshooting is required afterwards) and then work out who is the best and what is their prefferred platform. Of course cost is an issue but you usually get what you pay for and a bad tune = the need for a new motor = prob not worth skimping $200 for the cheaper tuner... In a similar vein, avoid Mine's tuned ECU's. not going into why here.
General consensus is that PowerFC or Z32+nistune is the way to go. Take into account whether having an aftermarket computer puts you in easy defect territory too (if so- nistune)
https://www.sau.com.au/forums/topic/396433-not-running/#findComment-6339786
  • 5 weeks later...
Hi All,
I'm a noob so I'm not sure if I'm on the right thread or not, but here goes..
Last night I did the mod where you ground out the boost solenoid on an R33GTSt.
Well I read the entire thread on that before attempting it, & then did it as specified.
When I went to test it on my way to work this morning it would not rev over 2500rpm, just kept coughing until i dropped the revs below 2500.
I freaked out (i only just got the car), & put it back to standard, but it still wont rev over 2500rpm..
Have I broken something? Can I fix this?
So far I have reset the ECU as specified (disconnect batt & pump brakes)
I hot wired the solenoid to see if it works (it does)
& I tried running the car with the solenoid grounded & ungrounded.
Still only 2500 rpm..
Please HELP!!!
https://www.sau.com.au/forums/topic/396433-not-running/#findComment-6380612
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
