Hey guys,
Just a quick question - When swapping over an old battery for a new one does it change any of the settings in the car? Do I need to reset anything?
My battery seems to be a little low on charge and I'm thinking of maybe buying a new one tomorrow, just don't want to take out the old one and put in a new one only to find out I did something wrong/stuffed up electrical settings.
ps. What model number is the standard battery? what model battery will fit/you guys using? - Can I buy a battery for the car from autobarn/supercheaps or do i need to go to a battery specialist? (I'm located in Adelaide)
Cheers, and I do apologise in advanced if this has already been covered, I couldn't seem to find much using google.
https://www.sau.com.au/forums/topic/396457-v35-battery/
the battery that came with my car died a few months after i bought it. replaced it with a centurey NS60LMF battery. no problems in the 2 years since i've replaced it.
http://www.centurybatteries.com.au/search/index.php/batteries/ID-190
when you replace the battery your trip counter will reset to 0000, not sure if there are any other problems. but that is the only thing that i have noticed.
https://www.sau.com.au/forums/topic/396457-v35-battery/#findComment-6297254
Cheers for that mate! looks like supercheap are a retailer so might drop by tomorrow. How much was the battery?
Just another quick one - 5mm spacers, are they safe to use? Just wanting my front wheels to come out a little bit.
Cheers guys
Edited by itpesaf
https://www.sau.com.au/forums/topic/396457-v35-battery/#findComment-6297262
Cheers - went with a century NS60L.
Chris my power window motors are stuffed, after installing the battery I installed a driver side power window motor which seemed to reset itself as when I open and close the door the window drops a little as it is meant to. I read somewhere that resetting is only necessary on the g35's?
https://www.sau.com.au/forums/topic/396457-v35-battery/#findComment-6298577
My auto up down feature works perfect, no reset needed - I believe ok jdm models when you close the door and open first time after installing motor it resets - only usdm models require reset. That being said Ive also heard some jdm models require reset so don't really know :S maybe I was just lucky and it reset itself :D
https://www.sau.com.au/forums/topic/396457-v35-battery/#findComment-6298706
Yeah i replaced the battery on mine everything was working fine didn't have to reset the window.
Not too sure on why USDM need to reset though as you said.
https://www.sau.com.au/forums/topic/396457-v35-battery/#findComment-6303242
