seeing as my r33 isnt my daily anymore i can finally start taking some parts off it.
i want to remove the rear window wiper.
How big is the hole in the rear window? as im going to order a plug to fill the hole, ive tried searching but nothing came up that helped
https://www.sau.com.au/forums/topic/396484-r33-rear-window/
I'm in the same boat as you and did this a few weeks ago. The large hole is 29.62mm.
I'm going to use the hole to put in a Battery Kill Switch as its both easy access to the battery and good location that is easily identifiable. I've used the smaller hole on the right for a GPS sensor that sits on the out side of the window and run the cable inside the cabin that goes to the Racepak dash.
https://www.sau.com.au/forums/topic/396484-r33-rear-window/#findComment-6298044
It's very simple. Remove the cover from the rear windscreen bolt on the base of the arm, undo that and then it's just a matter of a few other smaller bolts and you are done. Once you have a look at it, you will be fine in taking it off.
https://www.sau.com.au/forums/topic/396484-r33-rear-window/#findComment-6299107
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
