Jumped in my car this morning and it was making a weird high pitch buzzing/squeaking noise. It SOUNDS like a belt rubbing against something but I could not see anything. My dad says it may be a problem with a bearing, but I do not know what that means, as I am by no means a mechanic.
Took a short video from inside the car which is where I first heard it, then down to the left of the air intake near the fan where it seemed to be the loudest. My car is a r34 gtt, so a rb25det neo. The car is basically stock, bov, catback exhaust, hks mushroom air filter, bleeder valve + tune. Engine doesn't seem to be unresponsive or having any problems but I was too afraid to give it too much piss just incase something did happen. It is due for a service within a month, (every 5000kms, last service was a 100,000km) only done 102k kms. Anyone have any ideas?
Edited by voncina
https://www.sau.com.au/forums/topic/396487-engine-making-weird-noise/
take all the ancillary belts off one by one (remember that the one that goes on your fan also runs the water pump so dont run it for a long time with that off) and see if the noise goes away
It may be the idler pulley bearing for the A/C
Otherwise it may be underneath the timing cover, as said above, something may not have been done right in the 100,000km service or it may not have been done at all
Also have a feel of your crank angle sensor (on the front of the timing cover) just in case the bearing in there has gone. Mine used to make noises before I put my new CAS on, but they were different noises to that. Cant rule it out but
Edited by 89CAL
New belts will generally stretch after a a while. It even says to readjust them after installing.
Just watched the video. Did you have your A/C on while you were taking the vid? Cause my compressor sounds like that when engaged, just not as loud.
  • 1 month later...
Did you find out what the noise is?
Mine started the same noise from what looks the same place.
Will be taking belts off one by one this weekend.
Mine dont start making the sound until about 5-10 seconds after start up, then slowwwwly gets quieter and quieter. Similar?
Noise hasn't gone away, but is loudest and only really noticeable early morning when it is cold. I am pretty sure it is one of my belts because when the turbo timer is running and I hop out of the car there is another sound that actually sounds like a belt. When I get my next service I will just get the belts looked at, if something happens earlier I will blame my mechanic - I take it to a mechanic because I am not a mechanic. I pay him enough, my car should run perfect all the time. If it doesn't, I am going to rain shit on him.
Hey mate, no luck. I couldn't be f'd taking off all the belts, the power steering belt felt a bit loose so I gave it a tweak but nothing. I am pretty sure its coming from the timing train somewhere. Belt rub, pully or bearing. I have just had my timing belt done but like... 500km ago and its been quiet up till I take off the exhaust manifold . Makes me think its something I have done, but ummmm... Didn't work near that area. :huh:
Ive booked my car Wednesday to get it checked out. Just had a new engine dumped in so these sorta things have me on my toes. Ill let you know what he comes up with.
I am sure you have the same prob as mine, when car is cold its LOUD. Sound starts about 5 secs after running, slowly goes away after a few mins, will come back with minor revs till that slowley goes away and then only does it at high rpm.
See if there is somewhere (safe) on each of the items with a pulley (a/c, power steering etc.) and place the end of a very long screwdriver directly onto the casing of the metal as close as you can to the pulley and the other end to your ear while the engine is running, This will tell you straight away exactly which device/pulley is causing the noise, trust me you will know it when you hear it using this method. Then again on my commodore the thermo fan was electric so wasn't on all of the time like a belt driven fan so this was quite a bit safer lol
Hey Steve,
Mate I hate to say it... But check out your oil pump.
Mechanics taken all my belts off, still there. Taken off timing belt and swapped pullys etc. Still there.
Hes put a screwdriver where the oil pump would be? and is certain its the oil pump. He was blown away but swears it must be gears rubbing on the backplate or something. Oil pressure seems fine. Im fkn fuming because ive only had this engine in for aprox 600km and its causing me so much problems. I hope the oil pump is not your prob, but sounds VERY similar so check it out. Good luck to you Sir.
Hey Steve,
Cheers man, I will get my mechanic to look at it when I take it in for a service in about 1000kms or so. I got my stepdad to look at it, for a better opinion, he said it isn't anything that I should be worried about. Good enough for me :)
  • 2 months later...
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
