Hey Guys,
As the title suggests got a few standard and aftermarket bits for sale, all items are located on the Gold Coast but can be posted anywhere in Aus at buyers expense. I can be contacted on 0468963471 or at [email protected].
ALL ITEMS ARE FOR R33 GTST SERIES 1
Standard side mount intercooler + hard pipe, elbows and clamps- $50
Series 1 spoiler brake light-perfect condition - $20 (pretty sure I also have the spoiler to go with it in white but will confirm $30)
Standard washer bottle (no cap)- $15
Standard fuel pump + sock (works fine, great for testing/fault finding) - $25
Standard Injectors 370cc? x6 (also great for testing/fault finding-would recommend fitting new pindle caps for permanent use approx $10) - $50
Standard ECU manual - $100
Standard coil packs x6 (some showing signs of wear, again good for testing/fault finding) - $25
Standard gear knob perfect condition- $50
Mesh grille, series 1 or 1.5? (missing badge, looks better without badge IMO :) ) - $50
JJR Cold Air Intake Kit (black)- JJR CAI box assy, + pod filter, adapter and clamp - $100
Autometre Phantom 2 water temp guage (white face) + chrome cup - $30
I will now upload the pics :)
Edited by bsd-gtst
https://www.sau.com.au/forums/topic/396513-r33-gtst-s1-standard-bits-for-sale/
SORRY FOR THE LATE REPLY GUYS EMAILS ARE NOT UPDATING ME ABOUT POST :( PLEASE PM ME IF I DONT REPLY ON THIS POST :)
WILDERBOY, AAARH 33, YES CAI IS STILL FOR SALE, NOT SURE ON POSTAGE TO ACT I CAN GET A QUOTE
ESPRIT, MY TUNER ADVISED ME THAT THESE COIL PACKS WERE NOT QUITE HANDLING THE POWER I WAS MAKING 200RWKW, NOW THAT I HAVE REPLACED THEM I CAN SEE HEAT MARKS ON A COUPLE OF THEM WHICH I SUSPECT WAS THE PROBLEM, PROBABLY NOT SUITABLE TO USE AS A COMPLETE REPLACEMENT SET, HOWEVER THE OTHERS APPEAR TO BE FINE, MAYBE LOCATE WHICH OF YOURS ARE NOT COPING AND SWAP THEM OUT??
HAZER33, SORRY MATE NO FRONT BAR
GRILLE SOLD :D
just confirming I do also have the series 1 spoiler available in white, $50 complete with light or can seperate if need be.
all items apart from grille are still available :D
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
