Parts left over from GTR
1. RB26 VIRGIN ENGINE BLOCK (bare block in good condition comes with cradle) $650
2. RB26 ADJUSTABLE CAM GEARS (good condition) $150
3. POWER FC WITH HAND CONTROLLER & BOOST SENSOR (good condition a few pixels burn out on hand controller
screen) $650
4. GTR GEARBOX (working fine when in car) $500
5. EXEDY TWIN PLATE CLUTCH PUSH TYPE (working fine in car 70% meat left. RRP $2,350) $800
6. R32 GTR SUMP & DIFF $300
7. R33 C's SHORT SHIFTER NEW SUIT GTST $180
8. CUSTOM 3.5 INCH EXHAUST (front pipe to tip) $500
9. CUSCO STRUT BRACE $170
10. 18x9.5 BBS LM's $3500 (sold pending payment)
11. CUSTOM 3 POD HOLDER WITH DEFI BOOST, WATER & OIL TEMP GAUGES - DEFI CONTROLLER $500
12. ARC BLUE OIL CAP $70
13. RB26 STARTER MOTORS X 2 $100 EACH
14. CUSCO AIR DIVERSION PLATE $100
15. R32 GTR AIRBOX $400
16. R32 GTR QUARTER WINDOW GLASS (BOTH SIDES) $250
17. R32 GTR STEERING WHEEL (poor condition) $70
18. R32 GTR STOCK COMPUTER $150
19. R32 GTR POLISHED TURBO CROSSOVER PIPES $150
20. CATCH CAN (A) WITH LINES $150
21. CATCH CAN (B) $120
22. FUEL SURGE TANK $120
23. TURBO ELBOWS (A) $100
24. TURBO ELBOWS (B) $100
25. R32 GTR STOCK RADIATOR $50
26. R32 GTR ENGINE FAN $50
27. R32 GTR ALTERNATOR $100
28. R32 GTR BALLANCER & PULLEYS $50
29. R32 GTR WATER PUMP $30
30. NORGREN PRESSURE REG $100
31. R32 GTR 4WD COMPUTERS/SENSORS $450
32. R32 GTR CLIMATE CONTROL $50
33. R32 GTR KNOBS $50
34. R32 GTR STANDARD AFM'S $150
35. R32 GTR MIRROS (3 of - 1 with glass) $50 each
NEGOTIABLE ON SOME ITEMS
SAM 0439 702 702
LOCATED IN MELBOURNE
Edited by laspy
https://www.sau.com.au/forums/topic/396518-skyline-parts-mostly-gtr/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
