Parts left over from GTR
1. RB26 VIRGIN ENGINE BLOCK (bare block in good condition comes with cradle) $650
2. RB26 ADJUSTABLE CAM GEARS (good condition) $150
3. POWER FC WITH HAND CONTROLLER & BOOST SENSOR (good condition a few pixels burn out on hand controller
screen) $650
4. GTR GEARBOX (working fine when in car) $500
5. EXEDY TWIN PLATE CLUTCH PUSH TYPE (working fine in car 70% meat left. RRP $2,350) $800
6. R32 GTR SUMP & DIFF $300
7. R33 C's SHORT SHIFTER NEW SUIT GTST $180
8. CUSTOM 3.5 INCH EXHAUST (front pipe to tip) $500
9. CUSCO STRUT BRACE $170
10. 18x9.5 BBS LM's $3500 (sold pending payment)
11. CUSTOM 3 POD HOLDER WITH DEFI BOOST, WATER & OIL TEMP GAUGES - DEFI CONTROLLER $500
12. ARC BLUE OIL CAP $70
13. RB26 STARTER MOTORS X 2 $100 EACH
14. CUSCO AIR DIVERSION PLATE $100
15. R32 GTR AIRBOX $400
16. R32 GTR QUARTER WINDOW GLASS (BOTH SIDES) $250
17. R32 GTR STEERING WHEEL (poor condition) $70
18. R32 GTR STOCK COMPUTER $150
19. R32 GTR POLISHED TURBO CROSSOVER PIPES $150
20. CATCH CAN (A) WITH LINES $150
21. CATCH CAN (B) $120
22. FUEL SURGE TANK $120
23. TURBO ELBOWS (A) $100
24. TURBO ELBOWS (B) $100
25. R32 GTR STOCK RADIATOR $50
26. R32 GTR ENGINE FAN $50
27. R32 GTR ALTERNATOR $100
28. R32 GTR BALLANCER & PULLEYS $50
29. R32 GTR WATER PUMP $30
30. NORGREN PRESSURE REG $100
31. R32 GTR 4WD COMPUTERS/SENSORS $450
32. R32 GTR CLIMATE CONTROL $50
33. R32 GTR KNOBS $50
34. R32 GTR STANDARD AFM'S $150
35. R32 GTR MIRROS (3 of - 1 with glass) $50 each
NEGOTIABLE ON SOME ITEMS
SAM 0439 702 702
LOCATED IN MELBOURNE
Edited by laspy
https://www.sau.com.au/forums/topic/396518-skyline-parts-mostly-gtr/
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
    • Not the headlight. It's the DRL that serves double duty as white and amber. Would be the easiest way to make it happen, if fitting a BCM was in any way an easy thing. Otherwise you'd do it with some relay logic and/or maybe some diodes.
    • Would require a very smart body control module which these cars are about 20 years to old to have
