wrecking Nissan skyline r34 gtt 2000 red
lots of parts available just ask cheers
motor rb25 det neo complete $2500 ( 125,000kms)
gearbox $2000
pedal kit $200
tail shaft $200
flywheel $100
diff lsd $300
cv joints $150 pair
nismo shocks and springs $900
standard full exhaust system $300
brake master cylinder $120
front calipers $350
front disks $100
front hubs $150
rear hubs complete $300
upper control arms each $30
lower control arms each $70
cross member $100
rear upper control arms each $25
rear lower control arms each $70
power steering rack $150
Hicas $50
heater core 100
nismo wheels $1600
taillights $130 each
power window reg $150
ignition barrel plus door locks $170
blinkers switch on dash $40
ac display $120
rear bar $200
rear bar reinforcement $120
boot $600 with wing
boot shocks $70
doors $400 each
rear cut $1000
beaver panel $750
fuel flap $30
fuel cap $20
battery holder $20
washer bottle $50
radiator overflow $50
glass from $100
fuel tank $50
fuel pump $50
door trims $400 front and rear set immaculate
boot trims $100
interior light $20
seat belts (all 5 ) $150
dash $200
air bags $300
seats (front & back) $400 immaculate
antenna $50
call me on 0426504272 car is in Liverpool area
can post anything you want as well
Edited by anthony84
  • Replies 54
Hey Mate, I'm interested in the front brake calipers. Do they come with the bolts? Whats the lowest you'll do posted to 3021 VIC?
Cheers, Jason
PS: Your inbox is full
hey mate,
does nismo springs and shocks does that mean springs and 'coilovers'?
what is the age of them??
also nismo wheels, what model?? and tyre thread on them??
could you pm me some info on them??
Do you have the abs module ( alloy block in engine bay with 3 plugs)? how much
And abs wheel sensors 4 of them ?
the ecu on the right side of the boot on the back of the seat ( silver box ?
cheers
fyi.,,,
Some people might not realize series 2 car parts dont interchange with series 1 !!! Windows switches and electronics are way different they went to surface mount components and they wont work at All on cars pre8/2000
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
