Hey guys, been noticing more and more what look to be scratches (and paw prints) on my car from the neighborhood cats. They are not deep so they should polish out but I want to know how I could stop them getting on there...
I've bought a cover to hopefully try stop any marks of they do get on there, thought about baiting them although it isn't really viable as I've got 2 small dogs.
Anyone had any similar issues and any ideas how to prevent them? Was thinking of finding something cats really hate and spraying it on my car cover...
https://www.sau.com.au/forums/topic/396578-cats/
You think you got problems mate I have 2 rather large amstaffs that like to use the roof of my car as a lookout to see over the fence..was resprayed about 5 year ago now my paint is rooted..i tried building a fence and they tore it down..i tried kicking their heads in but it just makes them stupider..
The only success I have had is coating the car in wd40, that way they just slide off..but as you can imagine this isn't great to wash off..
But your best bet maybe coating your car in something the cat hates stuck to its fur, that way it will get sick when it licks itself..a heavy wax or something may do it..
GL...
https://www.sau.com.au/forums/topic/396578-cats/#findComment-6298897
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
