Im aiming for 200rwkw and no more... Don't wanna end up with too much of a fuel guzzler as i don't earn a shitload and have 3 mouths to feed. Once i reach that goal, if i still want more “fun factor” ill convert it to manual.
Direct from the RB25 dyno thread:
Cmon man, we all know that is a BS result...dont beleive evrything you see on the net.. :laugh:
Chris just get the Hypergear hiflow, proven performer with warranty.
I got carried away and have 270kws now and really dont need it, but luckily I only have 1 mouth to feed so far...
For 200kw just get a NIStune and fuel pump. If u already have a front mount and 3inch TBE.
Normally rb25s can make 200 on 11-12psi
Yep, just to add to what the guys above have said... The highflow turbo that was on my car had a reciept for $1900 highflow service and the turbo SHOULD have made good power but the best i got was a laggy 250rwkw and i blame the tuner for that result as the specs on that turbo on other cars make better power and are nice and responsive.
To give you feedback on price, i sold mine for $800 in excellent condition.
I would probably be inclined to point you towards the HG options etc based on others results.... My poor result made me change my whole turbo setup and it has cost a stupid amount of $$$ to do, so make the right choice the first time, dont bolt on an unknown as you will end up regretting it in most cases...
Stageas are gas guzzlers with the stock turbo let alone a highflow. If your budget is tight just wait for a second hand Nistuned ecu and then get it tuned with your stock turbo at 10psi - they run too rich from stock anyway.
At some point you should replace your fuel pump with a new genuine Walbro or similar.
Then save up for a 3in turbo back exhaust
Look out for a second hand return flow fmic.
Then get the most bargain basement HyperGear Highflow and remember you will have to budget for a tune as well and wind it up to the max your stock afm and injectors will handle and you will have a pretty zippy family wagon.
This is for my R34, my stagea is staying bog stock as its my family car, the 34 is gonna be my daily/car :)
And im looking forward to it using less fuel than my last daily (rb30 Efi patrol) while being ten times quicker.
Sorry this is not std AFM.
AFM is Z32.
Also another customer made 260kw at 15 psi.
http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page__st__720__p__5847954#entry5847954
Std injector never lean out at 15psi.
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
