Hey everyone selling a bunch of stuff ive hoarded over the years
Rims 17 x 9 +20 all round MULTISTUD dont know what they are maybe work? but says made in japan on the inside.
good size and offset come with 75% sumitomo z3 and 25% sumitomo z2. the z3 are my steer tyres at the moment and on the car still.
All rims have rash but nothing deep just paint missing. $950 with tyres or $750 without. Can take more pics if people want
cefiro exhaust tech twin flutes cat back $200
cefiro interior includes carpet, rear seats, parcel shelf trim, roof lining, sunroof + switches, centre console, 4 door trims, pretty much everything bar dash and front seats. $400 or can split sunroof and roof lining seperate from the rest
Cefiro wonder kit front, rear, sides excellent condition $350
Cefiro passenger side front seat - FREE
Drift shop castor rods minimal use $100
Drift shop toe rods minimal use but one is bent as seen in photo $50
Drift shop solid subframe bushes minimal use $50
S13 front swaybar 25mm thick $50
S13 front knuckles good for cut and shut job $120
brand new sealed in plastic bosch 040 $150 never used it went surge tank and 044 instead
r32 KYB shocks and king springs, firm but comfortable $250
Pretty firm on prices they are allready cheap
In Adelaide Golden Grove Area call Chris 0401 483 906
  • 4 weeks later...
  • 3 weeks later...
hey im looking for a few interior parts wondered if you still had them for sale.
both side read door handles
handbrake rubber handle
coin box cover by the fuses
drivers sunvisor
and maybe boot carpet only in black though if you have it?
im in albany WA would you be able to get a quote for postage
thanks =)
  • 7 months later...
  • 3 months later...
Hey m8, Do ypu have a Manual Centre Console and a gearstick surround console, Allso the Sunroof glass & The bosch in tank fuel pump, Let me know with prices Thanks Jamind
  • 3 weeks later...
I think I do have another manual console and gearstick surround I will have to check
The bosch pump sold a while ago, I have a complete sunroof not just the glass, make an offer but not a silly one
Thanks
  • 2 months later...
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
