It is a piece of cake.
A few tips:
- if you brake fluid is very full in the reservoir, remove some, as when you squeeze open the brake pads to put on the new/wider disks, fluid gets forced back into the reservior and will overflow if it is too full (I did this when I recently changed pads).
- open the brake bleed nipples to make squeezing the pads open easier, but once disks are fitted you should bleed them again anyway.
- buy braided brake lines (cheap = $200-$300) and put them on while you have it all apart.
Nope - never worked on handbrake shoes.
You can pull out the rubber grommet to get access to the rear hand brake adjusters and back them off a bit. But when I did mine last year the backing plate was held to the rotor by rust etc so you need to give the centre of the rotors a few hits with a club hammer to loosen same. I had to be quite brutal to free it up. It isnt particularly difficult other than for loosening the rear rotors.
  • 3 weeks later...
I'm putting DBA slotted Rotors all round On a factory 250GT (I presume sedans have same brakes as a 350Z touring yeah), braided brake lines and new brake pads
(can anyone reccomend some good ones), having my handbrake tightened while my coilovers are being put in..... Within the coming month
my previous experience with dba slotted rotors and bendix blue pads was not a good one... downhill braking resulted in smoking brakes, and pedal touching the floor. the pads when heated up literally had a chatter feel similar to dragging a wet washing glove on a plate
Edited by Deep Dish V35
  • 3 months later...
Bringing this thread alive again -
My rotors are showing wear, with visable lines on the face and discouloring. My brakes also squeel a lot in the cold or after rain in the morning when i first start driving.
I have had a bit of a look into Stoptech rotors and they seem to be reasonably priced, but if i'm upgrading rotors do i need to upgrade the capiler and pads too? I've got Brembo's 03 coupe.
No, although it would be best to do pads at the same time.
Just make sure that the rotors are for your brake package (ie 350z Track)
Thanks for the advice mate,
I have heard off my mate with a Supra to stay away from drilled rotors because they get really hot. Is this true? Would slotted Stoptechs fit in my wheels, i am about to buy a set of 20's.
Drilled rotors don't get any "hotter" than a normal rotor, that's a function of how hard you use the brakes.
The drilled holes become a stress riser due to localised heat and expansion & contraction of the rotor.
Just get some slotted ones; they still de gas the pad, and deglaze the rotor, that's where the benefit lies.
Brand is irrelevant, you have to buy rotors that have exactly the same dimensions as what you are running now; otherwise the caliper won't fit on.
The wheels not fitting will be the least of your worries.
I don't mean to offend.
With some of the basic questions you're asking; it might be better if you leave it to a professional, or at very least, have an experienced mate assist you with it the first time.
Brakes are not something you can afford to get even a little bit wrong.
Edited by Daleo
Excellent, thank you for that i understand it now. I will have to look up my dimensions then and go from there. No offence taken at all, i asked the question and requested information and that's what you guys are doing for me so i appreciate it. I just wanted a bit of an idea what to go with for now, my brakes will be fine for months to come so i'm not going to worry about it asap as i have money going on different things but i will keep this info in mind.
Of course, i would not try to fit them myself my Dad was a mechanic for 30 something years so i can always turn to him if i need something put on.
Best to get 2 piece floating rotors like I have - when the disk gets hot it expands and contracts independent of the rotor centre, eliminating the chance of disk warping.
Floating rotors aren't exactly a guarantee against warping, although the better quality base materials of a 2 piece rotor would certainly help.
The main reason for using 2 piece rotors (in my understanding) is that in high load conditions (i.e; trackwork) the alloy hat minimises the heat of the rotor transferring into the hub; and overheating the bearings causing a failure.
Good stuff, best of luck. :thumbsup:
Edited by Daleo
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
