  • Replies 193
Soon as I get paid tuesday night ill be faxing the forms through rolleyes.gif
keen to see what the changes are for this round!!
so you driving the 180 or the 4x4 this time? :laugh:
12. Dean Course R33 GTSt - you break it, you brought it. (in your case, you pay for it)
13. Campbell Shobbrook R33 GTSt - you break it, you brought it. (in your case, you fix it)
Got driveshafts? lol
I'll be there for the friday night and most of saturday morning so can help out with timing etc.
    • Stock ECU has compensation, you won't damage the engine. Personally I recommend getting an acceptable catalytic converter, it doesn't need to be OEM and super expensive but a cheap universal one to keep it from being super obnoxious to be around. Decatted cars smell pretty awful.
    • Correction. Ignition was on before, but I guess the car had to be running for it to work.
    • The stock ECU won't care. The gains from Nistuning the ECU and then "optimising" the fuel and ignition tables will be about 2 more HP.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
