I'm thinking of going to PI for the PIARC track day on the Sunday does that count?
ha, I push my luck to enter two events a month, let alone a weekend. If only it was my birthday, though I've already had too many of those for my liking!
  • Replies 193
Have a few mates going to PI for the PIARC day.. I just figured that Winton is closer.
Also going to winton this weekend as well, so hopefully my car doesn't break :P
i would but i dont really feel like replacing a bunch of parts when i get home as my car is stock as a rock
a stock car is more reliable than a modified one, also if your coming to spectate may as well volunteer to help us out ;)
yeah but these parts are all stock and alot of them original if i go around reving the S#%T out of it ill blow or butcher some old part or something like that, well that what ive been told by a relative who is a genius mechanic he said if i want to track it i should intall heavy duty parts that are designed to be givin a hammering + someone might crash into my car :P i just like to watch and enjoy :)
hmmm well stock parts are ment to handle what the car can do in stock form, but yeah thats my 2 cents (also im a mechanic)
anyways come along and have some fun. Bring a helmat, long sleeve shirt/jumper, long pants and you can also ride along with people ;)
as parts get older, wear out / deteriorate they may fail under heavy loads. well thats what ive been taught by someone i trust. full respect to your opinion i do keep an open mind with cars cause there are so many opinions!
ill definitly come along though thank you! would be cool to get a ride too see how my luck goes :3some:
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
