I'm thinking of going to PI for the PIARC track day on the Sunday does that count?
ha, I push my luck to enter two events a month, let alone a weekend. If only it was my birthday, though I've already had too many of those for my liking!
  • Replies 193
Have a few mates going to PI for the PIARC day.. I just figured that Winton is closer.
Also going to winton this weekend as well, so hopefully my car doesn't break :P
i would but i dont really feel like replacing a bunch of parts when i get home as my car is stock as a rock
a stock car is more reliable than a modified one, also if your coming to spectate may as well volunteer to help us out ;)
yeah but these parts are all stock and alot of them original if i go around reving the S#%T out of it ill blow or butcher some old part or something like that, well that what ive been told by a relative who is a genius mechanic he said if i want to track it i should intall heavy duty parts that are designed to be givin a hammering + someone might crash into my car :P i just like to watch and enjoy :)
hmmm well stock parts are ment to handle what the car can do in stock form, but yeah thats my 2 cents (also im a mechanic)
anyways come along and have some fun. Bring a helmat, long sleeve shirt/jumper, long pants and you can also ride along with people ;)
as parts get older, wear out / deteriorate they may fail under heavy loads. well thats what ive been taught by someone i trust. full respect to your opinion i do keep an open mind with cars cause there are so many opinions!
ill definitly come along though thank you! would be cool to get a ride too see how my luck goes :3some:
    • Too much work, but guess I will have to
    • qld plates “GTR R34” for sale $5500 (listed else where)
    • Or, just take PS pump off and inspect? Does no-one do this any more?
    • Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes   i will raise the front of the car and will turn side to side to test id bubble goes away
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
