I'm off to party in Sydney! I'll think of you as I am eating Zumbo creations and drinking copious amounts of alcohol :yucky:
hmmm.... i guess as long as your drinking.... that should be ok then
  • Replies 193
Good day :)
drive up, weather, organisation (thanks guys, volunteers) layouts, lunch, crapping on lots, drive back.
Perfect everything. Looking forward to the next round.
Sorry I had to bail early, but I had a mate's birthday to go to on Sat night. As per usual, a flawlessly run event thanks to the guys running it and the volunteers who give of their time event after event - can't thank you guys enough. First time out in the S13 for me and unfortunately the ol' gearbox is pretty much f*(&^%D and I had no second gear most of the time. So I pretty much just baked it in first the whole time. New box is ready to go in so that shouldn't be a problem next time!
New oil cap sourced. Thinking of connecting it to a chain that's welded to the rad support. Then I can't lose it again :D
Can't wait for next time guys!
    • Stock ECU has compensation, you won't damage the engine. Personally I recommend getting an acceptable catalytic converter, it doesn't need to be OEM and super expensive but a cheap universal one to keep it from being super obnoxious to be around. Decatted cars smell pretty awful.
    • Correction. Ignition was on before, but I guess the car had to be running for it to work.
    • The stock ECU won't care. The gains from Nistuning the ECU and then "optimising" the fuel and ignition tables will be about 2 more HP.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
