what do volunteers get them selfes into?
Straight away you become a rockstar in your SAU Officials vest.
We need volunteers to help with starting off the cars, timing and keeping a eye on the cars on the track.
We hook ya up with drinks and pay for your lunch.
And if you come out with us on saturday night you may find a drink or 2 heading your way.
So if you could help out that would be fantastic.
  • Replies 193
oh wow that sounds like fun but ive never done anything like that before what if i make a mistake or not sure of something? :wacko:
If timing is not your thing i can find something easy like letting the cars in and out of the starting or finishing gates.
easy as mate. Would not put you anywhere you were not cunfortable with.
And if your coming up to watch i can get you right up close to the action.
Its also 1 of the best way to meet other club members.
Good stuff. I'm posting myself on the Mini Wang this time, if there's two spots you are more than welcome to join me and I'll keep you company/show you what to do. Or you might want to volunteer on the skidpan instead as you'll get to be around more people and cars. Either way you'll have a ball.
Guest
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
