Its a snake thats living under the plenum.
Send an Owl to Harry Potter and ask him to translate, he can speak Parseltongue.
Have you tried increasing the revs a bit to see if it does it above idle? Change the hose on the FPR?
Maybe post a video. Cars make all sorts of noises and people describe them differently so its hard to E-Mechanic it. But my stock injectors and my Nismo ones definitely dont hiss at all at idle.
https://www.sau.com.au/forums/topic/396689-hissing/#findComment-6300192
There is a PCV hose that is plumbed into the rocker cover near the front of the plenum. It is connected via a push-in one-way valve.
Mine sometimes has a hiss from there- maybe have a look at that? Might have dislodged it/damaged it when replacing injectors.
If not, shoot it with a 12 gauge but leave one in the pipe in case the snakes are hunting in pairs.
https://www.sau.com.au/forums/topic/396689-hissing/#findComment-6300580
I checked the lines and cant find the point of the hissing.
Might rig up some ear muffs with a hose on the end to pinpoint it.
Hermione rocked my world last night I just sent her to your place via platform 9 and 3 quarters.
Ohh and Game Of Thrones is an epic story of knights & dragons etc.
Recommend it heavily
https://www.sau.com.au/forums/topic/396689-hissing/#findComment-6301009
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
