Going through and reading pages on pages of info, I'm getting confused...
With basic bolt ones, injectors, exhaust, power fc etc
Which GTR is the quickest straight line? 32 33 or 34?
Does it just come down to the 32 being the lightest? Or does the 34 make up for it being newer etc etc??
https://www.sau.com.au/forums/topic/396726-gtrs/
Yes you certainly are confused.
The one with the most power/torque and least weight will win if all other variables are the same.
https://www.sau.com.au/forums/topic/396726-gtrs/#findComment-6300690
No of course kw all being the same etc. But if you bolt the same mods on each of the models you won't get the same torque and kws correct?
Then take weight into account etc??
Lol can't afford a 35 and not keen on a 31...
32 33 or 34
https://www.sau.com.au/forums/topic/396726-gtrs/#findComment-6300702
There is no golden answer other than this:
https://www.sau.com.au/forums/topic/396726-gtrs/#findComment-6300792
I kno each car would be different car from car even in the same model.
But there must be something like a tune with basic bolt ones a 34 will be quicker or the 32 won't have as many kws but much lighter. So quicker in a straight line and on the track etc
https://www.sau.com.au/forums/topic/396726-gtrs/#findComment-6300811
this is my personal view on the topic...
if all 3 were brand new and had identical mods done, including supporting mods, they would all end up with about the same power.
if you then gave them all the same power, same gear ratios, same WEIGHT - then they will go as well as either or.
so in the end, engine condition, weight, ratios in no order make up the winning combo assuming power is equal.
k, done. lock.
https://www.sau.com.au/forums/topic/396726-gtrs/#findComment-6300835
Yer but do you need more money and parts to make a 32 rb26 put out the same as a r34rb26?
What I'm saying is I spend $2000 on a power fc some injectors and a tune and your saying all 3 models will put
Out roughly the same kws? Etc
https://www.sau.com.au/forums/topic/396726-gtrs/#findComment-6300842
What's so good about the 33 system?
Exhaust manifolds, aftermarket dumps and front popes are common between all 3 ( except for the O2 sensor bung sizes in the 32 and EGT temp probe in the V Spec and above versions of the 34). It's common knowledge that a 33 GTR cat back will bolt into a 34 with a few minor hanger changes and a bee's dick shorter.
So, where does this magical 30 HP come from?
Wouldn't it also depend if it was a 300 HP car or a 1300 HP car?
https://www.sau.com.au/forums/topic/396726-gtrs/#findComment-6300845
The cosmos of course
How?
The R34 is heavier. The R33 is heavier.
So once again....
The one with ... least weight will win if all other variables are the same.
https://www.sau.com.au/forums/topic/396726-gtrs/#findComment-6300873
L2belessserious
Lol
https://www.sau.com.au/forums/topic/396726-gtrs/#findComment-6300877
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
