I may have made a mistake, my pump kit came with a black rubber sock/sleeve that goes over the pump for when it's mounted externally to stop vibrations etc while clamped down....
I put that around the body of the pump submerged in the tank in ethanol....I'm going to check it this avo I have a feeling it's starting to perish and block the intake sock on the pump lol
  • 1 year later...
Sorry about the thread revival guys, but I am at a moot point regarding fuel pumps and it is driving me mad.
What I plan on doing is running a pump on its own (With the intentions of it becoming a lift pump once I need more fuel).
I have a brand new Nismo 275lph @ 80psi pump sitting in a box wrapped in plastic. I've been told not to use it for E85, and I want to use E85. People have told me to get a Walbro 400lph pump which is E85 compatible. So I did some homework:
The walbro 400lph isn't exactly that. (I have attached flow diagrams)
It flows 315lph at 70psi (45psi base, 25psi of boost)
Nismo flows 275lph @ 80 psi which I estimate to be over 300lph at 70psi.
Anyway - should I just drop the Nismo in and run E85 through it and be done with it?
I love Nismo pumps. So quiet, small, and, its Nismo!
The ethanol version of the Walbro is absolutely silent, quieter than the Nismo/Tomei pumps. It uses a turbine vane, not an oil pump style gear type of old.
If you want ethanol compatibility there is only one choice, that said, you may get many years out of the Nismo. Personally I would sell the Nismo off and buy the 460 Walbro, and pocket the change.
Mr Mafia is that the R33 GTR or GTS25T Nismo pump ?
Personally I think an EFI pump that draws 18-20 amps on its own is hardly current tech electrics . I think the GTR Nismo is advertised as drawing 8 or 9 .
A .
R34 GTR Nismo pump Disco stu :)
If it's a 8-9 amp pump, what does this mean for me?
And works with the factory fpcm, but I don't think Mafia needs that. :P
haha actually... yes I do. I am running a Nistune (R32 GTR ECU in my R34 GTR). Works really well.
Have you, or are you planning to direct wire the pump through a relay? The stock wiring won't support the Walbro.
Twice the current draw from a battery that's sometimes not real close to the alternator .
I haven't looked that closely into the fuel pump control modules , basically they are like a ballast resistor with a fancy relay to bypass it when the computer says so . With GTRs the FPCM has two stages or resistors and the usual bypass . Nissans like the Q45 V8s in the US use the same type of thing and at one of their sites they have pics of them opened up and in various stages of melt down - literally .
Their purpose was to minimise the amount of fuel doing circuits at low revs and loads and to shut the pump up to a degree .
The upshot is that the standard wiring won't appreciate more than double the fuel pumps normal current draw which is why the bolt in Nismo pump works with the standard system .
One feller many years ago reckoned an easy way is to leave the std or similar pump in tank and run an external pump to do the hard stuff . A standardish pump should easily cope feeding into the external because its not creating the rails pressure head on its own . . And its not like either pump can run away speed wise because all the fuel is going to the same place . External pumps make the wiring easy because there's no fuel tank to feed/seal wires into . Bonus is they're easy to change if you mount them in an accessible place .
In a way running pumps in circuit is like running several in tank because logically the fuel all goes to the same place . The difference is that running them in series rather than parallel means they share the work load and if primary isn't a gorilla pump it doesn't matter . If the external tries to pump more than the in tank its flow increases because the effective pressure ahead is less .
A .
No, the Nismo works on the stock system because it is designed to run on low voltage, and not draw too much current for the stock wiring when doing so. Try running a Walbro 255 on stock cruise voltages and you will find it doesn't last very long.
Personally I run twin 255's for that very reason, more flow for less current, but they are not ethanol rated. These days I would be dropping an e85 460 in, as I am doing to my evo this week.
Running the stock pump with an inline after it is a good idea, but you would need to match the sizes of the pumps. No way a little 20 year old oem stock pump will flow enough to keep up with a decent inline, and that would cause all sorts of problems.
  • 4 weeks later...
lol so I am still confused. Should I just use the Nismo for my intank pump for E85, and then upgrade to a surge tank when I need more and then use the nismo as a lift pump?
Thats what I did had the nismo initially and then it became my lift pump when I went surge so far 4 years on e85 and no problem.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
