mine surged on 1/4 tank Lol
so you're pretty lucky to not surge on E
Agreed - mine also starts to surge at around a quarter tank. Sard pump with all the stock mounting stuff. Jez needs to corner faster :devil:
The sudden loss of all power is a give away - no wideband required.
So after a long day of testing today, they problem is as follows.
The pump has a main inlet where the hose and sock are connected, then there are 2 little holes where the fuel comes out. A priming/flow method for the pump.
Once the fuel level gets to below the fuel pump (where the 2 holes are exposed to air) the fuel pump needs 5 or 6 seconds of priming from a constant 12 volts before it starts to flow. In a GTR with a 0.7 sec priming cycle added to fuel rail pressure and the time it takes large injectors to fire = a long time of cranking over.
Now this is only a problem in applications where the fuel pump does not sit at the bottom of the tank i.e 33 34 GTR's. 32GTR's have a different fuel pick up set up hence no problem.
So seeing as I was the first 33GTR in unigroup to try the 400lph I was the lucky customer to be the guinea pig :S. boo I say.
Any way the solution Bosch 044 in tank haha.
Maybe nismoid can put this in his "handy threads" sticky to make it known for anyone who wants to run a 400lph Walbro, NOT to do so if the fuel pump is mounted in any other way other than close to the bottom.
Cheers
The dutch
Surely if the priming time was the issue you could extend the prime time? Why not give it a constant 12v.
Well if youve already put the 044 then thats that I guess.
Wanna sell your 400LPH?
The priming time would have to be changed to 8sec. Now that can be avoided if I just go to a 044.
As I said, I was at Unigroup all of yesterday, and we were testing pumps left right and centre. Tested 3 walbro 400lph outside the tank, and tested a 044.
The 400l was fine when submerged but no good when exposed to air. Did I really want a priming cycle of 8sec or maybe even more every time? No.
So we rigged up a 044 and did a swap, my 400l for the Bosch.
In short, sorry mate don't have the pump.
Cheers
The dutch
so the whole pump needs to be submerged ie if i was to mount it on the bottom of the tank it should be right? any one know how these go in a stagea 260rs 1999?how do these wire up?
Edited by R33huntme
Dave posted saying he knows how to "fix it" and he does, last time I was at Enique I was shown why they don't work when not submerged and it is a quick simple thing to fix, shot Dave a pm and I sure he would be willing to explain it, he is a really nice guy if you don't make yourself come across as a f**k stick
Lol, thanks.
He actually took the liberty of pm'ing me. He did inform me to block off 1 of the two holes associated with the priming system. Now thats all good and well, but leave that pump for long enough unsubmerged and the fuel leaks out again.
Either way, we tested them, saw how they worked, blocked off holes, submerged it, left it out of fuel, we did everything bar taking the bloody thing apart.
Its a shame they have to be modified. But I dont mind the 044. Still quiter than my stock pump I had. haha.
yes, quick and easy fix. and they are on special at vpw for like 120 dollars..
hopfully they realise this fault and re-design the inlet acordingly. you cant just block them up either as it doesnt alow for the pump to self prime. if they are fully submerged the whole time there output goes up heaps with both the bleed holes blocked. :0
  • 3 months later...
Just installed 1 into r33 GTR. So far no issue's even on empty but testing to see.
Looking at how hight the pump sits in tank i would think it needs alot more than 1/4 tank to be submerged.
What is the mod that u speak of Dave?
My fuel light is on and it is still fine Jez
If they dont have the bleed holes then they will work.
Also remember that the car drove fine all the way to empty. But as soon as you shut it off and leave it for an hour (enough time for the fuel pump to bleed off) then the car would not start with approx 15l in the tank
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
