Im sure that the shafts fit, but the A-arms are different (sway bar mounts, handbrake cables and mounts, adjustable bits here and there) I had a few and measured them up, by eye they could be made to fit, but unsure if theres any benefit??
An entire R33 rear end would be interesting though....
yea thats what i wasnt sure about my mate reckons there abit wider as well so will push the track out.
basically my rear rotors/calipers are absolutely shagged. im looking @ using z31 disc with r32 calipers on dog legs. ive measured it all up and confident itl work, but you loose the handbrake, so thats why i was thinking change to hr a arms.
yea been thinking goin s14 rear with 33diff and shafts. just wheighing up cost @ moment. but yea would be ideal
If they do fit,(possible, they are close) the rear end goemetry will be all kinds of Shit. Toe will be different, for one, and will probably shred your tyres. The only way to make it work is to use all of the suspension, not just the arms
i run hr31 arms in my dr30 and c210. use r30 crossmember, c210 crossmember has different geometry and the hr31 crossmember is no use as the floor pins are further apart. i run hr31 4bolt cv shafts and all lines up. the inner arm mounts on hr31 have cam adjusters and is a larger size bolt so either drill out crossmember bracket to suit and use larger bolt ( ithink i used qg patrol trailing arm bolts) or cut/fit/weld adjustable bracket off hr31 crossmember. i modified r30 drumbrake handbrake cables and work fine with the inner handbrake ass. there is a gain in track around 20mm per side ithink... been awhile.
jon.
sweet ! cheers jon! maybe i will pursue it now.. i can deal with 20mm more track and the mods to the subframe,etc.. still allot cheaper than goin s14 rear end lol. have u had it on a wheel aligner or notice any other differences? car still handles the same?
Edited by ydr030
r30 and hr31 have same geometry so no different, if u try'd fitting hr31 arms to c210 crossmember itd be wack.
i also run the hr31 swaybars didnt even try the original r30 rear.
if your needing any hr31 rear end parts letme know ive got a few complete rear ends there 4.3 clutchpack, 4 bolt cv's etc
jon.
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
