OK i get the feeling im about to get a bit scrutiny but i would like to know if it is possible to put a Rb26 Dett in my r34 25gt
The reason being is i am going on my opens shortly and i would like more power.
Is it worth me selling my R34 25gt and buying a 25gt-t and live with the power it has or put a r26 in my car?
This car is used to drift when i can find the time and or money, but is also my daily.
The Car: Nissan Skyline r34 25GT 1998 Manual
I have upgraded to the turbo lsd diff with shim out of the r34 GT-T,
I have Upgraded my brakes from the r34 GT-T front and rear ( 4 pot front, 2 pot Rear)
I have upgraded to the exedy heavy duty clutch.
And a few other things that dont matter here like hid`s in my xennons etc
https://www.sau.com.au/forums/topic/396781-r34-25gt-na-to-rb26-conversion/
Anything is possible. Is it realistically worth the cost?
Option 1
A RB26 conversion with a complete motor/piping/airbox/loom/labour is going to cost you 5-6k, and realistically you'd change the turbos before installing the motor so thats another $2500. Then FMIC, exhaust, fuel pump potentially coil packs... There goes another $2000. Then your clutch doesn't sound like it'll hold the power so factor that in as well. It'll be a 10k trip to do it properly.
You'll have around 270-320rwkw and a car that'll still handle and brake like shit. 10k spent easily as brakes/suspension is not factored in here.
Option 2
Sell and buy a GT-t
Simply get a FMIC, ECU/exhaust/fuel pump and you'll probably find thats enough to keep you going for a while with 200rwkw or so whilst you learn to drive it. You might even pickup one with a few mods on it easily enough - Let someone else spend the money, you benefit.
Once you are proficient upgrade brakes & suspension, if you have cash left over then change turbo (factory replacement lotmount)/injectors/AFM and end up with around 260-280rwkw. Another $5000 there as well.
You'll have around 260-280rwkw, plenty of experience and most importantly - A car that'll brake and handle MUCH better, which is faster. Under 10k spent.
Pretty easy to see why Option 2 is the far better choice. A RB26 isn't the be all and end all.
It isn't worth the money.
Even better than option 2 is option 3:
Buy a GTS-T with all those mods already for a fraction of the cost, the owner will probably have f**ked half them up, but it is still cheaper to fix his average mods then to start from scratch.
The conversion to do it properly will cost around 9 to 10 grand unless you shop for bargains. You will need a fair bit of customizing sumps and exhaust stuff like that costs a fair bit plus the engine with a 3 grand price tag along with ecu and loom. You also need to decide if you want to keep it stock or upgrade things before hand.
Shopping list
Rb26 2 to 3 grand for a decent one
Loom and ecu 400
Sump conversion 300+
Front pipes 300 to 500
Front mount with piping 500 to ?
New gaskets and other good to buy bits 500+
new heater hoses 300+
safety money 1000
Labour 4000+
I would say 4k+ for a decent 26, 2-3k would be an average 32gtr motor
I would say depends how much money you have to spend. It doesn't seem that easy these days to "just" sell your car the way the market it is could take ages unless you sell it real cheap. You could just buy a Turbs neo motor which would be the easiest route for a conversion, and 25's are alot cheaper to fix if you plan to drift it every now and again.
It's easy to sell a car, price it to sell. I mean people still think they can get 30k for a stock motor R33 GTR with a bolt ons... They are kidding themselves. The cars are 15+ years old.
N/A R34s seem to sell quite easily due to all the new p-plate restrictions in most states. You get the good looks of the R34 and the motor isn't a total gutless wonder for what it is. It's all about pricing it appropriately and being realistic.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
