Rocker Cover Breathers Dash -10 Size
Hi Guys, I had a batch of these breathers made from Aluminium for my mates and my skylines. I had to get a whole batch made up otherwise the cnc guy couldn't be bothered just making a couple.
Rocker Cover Breather Dash -10 Size, they replace the stock breathers by push-fitting them, instead going to the hassle of welding breathers or AN adaptors to rocker covers.
Made from Aluminium, and replace the standard rocker cover breathers so you can use a -10 screw on fitting like Speedflow/Earls/PFE etc
Suits RB20, RB25 and RB26.
$50 a pair - including postage.
PM if interested!
Here are the fittings on my rocker covers, with black AN fittings screwed on.
The aluminium fittings fit very snugly in to the rocker cover breather holes, no need for any sealant. Can definitely vouch for the quality of these fittings.
Edit: Tried to upload a 100kb picture, but kept getting 'IO error'... Weird. I'll try again later.
Edited by Chainfire
Thanks for the positive feedback!
maybe PM me the pic, and i'll try to upload it to my gallery, if its not working for you...
Cheers
I used a blanking cap/flare cap on top to tap them in. The ends are chamfered to make it easier to tap in at a straight angle. Sometimes its easier to remove/fit when the rocker covers are hot after a short drive.
Here's a speedflow flare cap: http://www.speedflow...u/adapters.html but you can get them on ebay for $8.
You can block off the side breather on a RB25 if you want.
 Share
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
