Hi Guys,
Been awhile since I've been on here and it's time to sell my ute!
Work has decided to give me a work car so it's time to sell and get back into an import.
The Details:
Heavy-duty Hayman Reese tow bar (never used!)
Heavy-duty lowered springs all round
New shocks
Brake discs and pads replaced over Christmas
Car has just had major service over Christmas
Belts replaced last year
Radiator replaced last year (full system flush)
Hoses replaced last year
Genuine Holden tray liner
19" wheels
Sports exhaust
Tinted windows
The Bad:
Driver's seat has tear in side bolster
Gutter rash on passenger wheels (whoops)
Not fitted but also included:
VZ Monaro front bar and headlights
Set of stock wheels
Sports bar
Sub box which fits behind the drivers seat - no sub included
As I've already stated I had set this up to tow but never did.
Premium fuel always used and serviced every 5000kms.
235 500kms, which are mainly highway km's. I do a lot of driving between Geelong, Ballarat, Melbourne and the occasional to Shep / other middle of ass-backward nowhere towns (no great offense intended)
Car is located in Geelong VIC
Please pm me as I'm pretty much always near my computer
$13500 without rwc
REG paid till APRIL 2013!!!
Edited by stealth-ish
https://www.sau.com.au/forums/topic/396840-fs-vic-2002-holden-vu-ute/
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
