Hi all. Havent been here for awhile, so I thought id share some good news. After numerious problems with my car, we finally found some reliablity and came out class B winner for the weekend, while almost everyone else had dramas. The only problem we had was a lack of power, the car is tuned with 300kws, but some of that seems to have gone awol! Did find were some of it was going, out though a loose bolt on the the dump pipe, but once that was done up, it still didnt feel super quick like it did before. We have had the head off, so maybe we didnt get the cams spot on, so it will get tuned before we race again.
managed a fastest lap of 61.6 for the weekend, but should of been able to do 60's if all the power was there.
ive uploaded a couple of video to youface.
My link
My link
Looking good man, a couple of guys from SAU were up there on Sunday (myself included) and it turned out to be an awesome day.
61.6 is a good solid time, but 60's at symmons would be a great base time ;)
so says you... Mr 70s :P
You're such a super troll Mr. Nowell, what's your best time around symmons again? Oh yeah, that's right... :P
I've never even driven symmons. Just commenting on times in regards to the competition like every other joker out here, not comparing them to anything I've even experienced ;)
You should be stoked just to have finished with the problems that everyone else had.
When are you coming up for some laps trollbermerc?
It was crazy watching the race on Sunday, half the field disappeared by the end of the race :P
I'm pretty sure he's coming up for some quarter laps (drifting) this weekend :)
To everyone anyone that didn't run this event and could’ve... sorry, but you seriously missed out!
I wasn't that fussed about running at the V8s in the past, but with my car finally up and running and with some tyres, pads and rotors left-over from Rally Tas, at the very last minute I thought why no let’s do it.
For me it was such a cruisey reintroduction in to circuit racing with zero pressure... so much so I missed qualifying due to a minor (clutch master cylinder) issue, and instead of fixing it straight away we watched qualifying then sorted it!
It was fun getting the hang of the 'new' car on the track (particularly off the back of the grid in race one!), re-understanding tyre performance checking out cooling temperates etc... and generally enjoying some dicing with a bunch of top guys and it was pretty cool just being part of the V8 circus.
One of the best things about the Invitationals was the race lengths. I always enjoyed the longer races back in 2004 when I last did a full circuit season in the R32 with 12 and 15 lap races.
Being out there for 12 laps at the V8s was great fun. Five laps like usual TSS rounds are just too short, seven fine, ten great... 12 or 15 would be awesome again.
If you have a car able to compete and the V8SC offer the opportunity for this category to run again in 2013, don't give it a second though, just get amongst it!
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
