  • Replies 191
I can do 6x of the injectors for $720 incl. delivery.
They are all flow matched.
Required extensions and plugs would be an extra $95 for all 6.
Hey,
I can do some SARD 800cc side feed (high impedance) injectors for $145/injector incl. delivery.
- Brendan
Hey mate after 650cc side feeds for SR20, not fussed on brand just want some prices cheers
Hey mate,
Side feed injectors are not common these days, I can do any choice of 540cc, 550cc or 800cc SARD ones for $590 incl. delivery (Express) for the 4x.
- Brendan
after a price on a set of 1000cc and 2000cc injectors for rb26
Hey,
I would go with EV 14's in the 1000cc size, they are a popular RB26 choice with us.
The injectors including extensions and plugs would be $630 incl. delivery (Express)
For the other ones you can't go wrong with the BOSCH 2200cc ones, I can do 6x of them with all extensions and plugs to suit for $780 incl. delivery (Express).
Let me know what you decide, these are very popular injectors and great deals on them as well.
- Brendan
How much for 6x top feed ID1000cc injectors for r32 gtr
Hi,
6x ID1000cc (BOSCH EV14's) with extensions and plugs to suit GTR would be $600 incl. delivery
- Brendan
Hey,
- Brendan
hey mate can i get a set of the BOSCH 2200cc ones with all extensions and plugs to suit for $780 incl. delivery (Express) pm sent
Sure thing mate, I'll PM you details now.
Hey,
I can do 4x BOSCH EV14's 1000cc (flow matched) including extensions and plugs to suit for $430 incl. delivery or the 2200cc short's for $580 incl. delivery again with all extensions and plugs.
- Brendan
Hey mate,
What's your largest side feed injector? And price?
After 6
Thanks
Hi,
I can do 6x SARD 800cc side feed injectors for $880 incl. delivery.
I can supply plugs as well if required.
Cheers,
Brendan
  • 2 months later...
Hey mate how much for a set 875cc for r33 gtst
Hey,
Are you using the standard side feed injectors? - only option would be SARD one's then.
- Brendan
I would like to get some injectors to suit my R34 GT-T RB25 NEO and would like to go with the injector dynamics.
Can you supply these as a direct fit with whatever plugs and adapters etc are necassary?
Please get me a price for a drop in solution using injector dynamics id850 or id1000s.
Also it is my understanding that id1000s are bosch ev14s, but injector dynamics flow match them and provide a flow report with each set of injectors. From what I have read they also mill downs the ends and modify them in some way. Can you confirm this?
Thanks
Edited by vkadam
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
