Trying to find a set of preferably ID2000's to suit R34 RB25 NEO running E85.
Hey,
We have the injector's which are BOSCH 2200cc however they are not match flowed by injector dynamics but by a different mob.
- Brendan
  • Replies 191
Hey Brendan,
I'm looking for some top feed high imp injectors for an E85 convert for my NEO. Whats the cheapest option for anything 600c and higher?
Thanks,
Tom
Price on id2000 for r33 gtr 11mm with adapters etc for standard rail.
Hi,
Price on the lot would be $840 incl. delivery. That's the BOSCH 2200cc injectors, plugs and 11mm o-ring extensions.
- Brendan
Would you have a price for a new set of 440cc for a stock set-up?
Hi,
Are you referring to the green BOSCH injectors? How many do you require?
- Brendan
Hey Brendan,
Thanks,
Tom
Hi Tom,
You can't go wrong with the BOSCH EV14's, top feed, 725cc.
They are E85 compatible and I can do a set incl. plugs and extensions for $590 incl. delivery.
Cheers,
Brendan
(VM)
Hi Tom,
Cheers,
Brendan
(VM)
Thanks Brendon. So they are 100% plug straight in for the NEO engine?
Sounds great, if I could also grab a price on a set of 850cc or higher that would be awesome, as I'll also be getting another set of 6 for a mate.
Thanks for your time,
Tom
Tom
Hi,
They will require professional installation and the harness would most likely need to be hard-wired with the plugs provided. These are universal injectors but are very common today on all RB series engines.
The ones up from the 725cc are the 1000cc which are $640 for the entire set-up.
- Brendan
Hi,
- Brendan
Thanks Brendan,
I'll get back to you with my order.
cheers,
Tom
after 2200cc injectors to suit a vq35det can you help me out and a price please mate
Hey,
I can do 6x of the BOSCH 2200cc injectors for $830 incl. delivery.
This would include extensions to suit either 11mm or 14mm o-ring size and Denso plug's.
Let me know what you think,
Brendan
(VM)
  • 3 weeks later...
Chasing a quote on ID1000cc and ID2000cc for a R32 GTR using standard fuel rail. Including extensions etc for fitment to stock rail.
Cheers
Adrian
Cheers
Adrian
Hey Adrian,
Price on a set off the 1000cc injectors would be $640 and 2200cc injectors would be $820.
Both price are inclusive of delivery and come with the required 11mm o-ring extensions and plugs.
- Brendan
  • 1 month later...
Hi after a price on ID 1000s and I'D 2000s 11mm drop in kit for a standard r32 gtr fuel rail
I want the ID as they are supposed to come with dead time compensation values across the entire pressure and voltage range
Hey,
We don't stock the ID flow matched injectors, our ones are flow matched by a sister company.
The injectors themselves are identical BOSCH EV14's to what injector dynamics use.
We also don't do a drop in kit's for the GTR, some modifications will be required.
Let me know what you thin,
- Brendan
(VM)
This guy, Brendan, super awesome service. Took my call after hours and sorted payment within the hour. Had it posted the next day! Can't speak highly enough of the service and I'm definitely going to keep coming back. Good work man
