Ok Kool so I just had a good talk to the shop tuning my car today, I'm going to go for 1000cc injectors, I need something to fit top feed, 11mm o ring and to suit loom or if not supply plugs to be re wired ect... If I could grab a price that would be great,
Also whets the shipping turnaround time on these to Sydney? Cheers
PM sent mate. We can do it :yes:
  • 4 weeks later...
  • Replies 191
Hello Brendan I am chasing a set of 850cc injectors to fit a 1996 Ser2 RB25DET Skyline. I would prefer a direct fit for the above model if possible. Availability ,price and lead time for delivery to Brisbane. Thank you
Hi,
Nothing would really be a direct fit in that CC range so you would need to go to 1000cc to be an easier fit like the EV14's.
Let me know,
Brendan
(VM)
Hi,
Let me know,
Brendan
(VM)
Hi,
I do not mind if I have to change the electrical connections I am more concerned with them fitting the factory fuel rail for side feeds, do you have anything in the 850cc range that will do this?
Sean Palm
  • 3 weeks later...
  • 2 months later...
hey brendan
have you got any thing to suit an rb25det neo? direct fit or as close to direct as possible? was looking for something around the 600-700cc range
cheers
hey brendan
cheers
Hey!
Being a top feed set-up the EV14's would be a good choice I would say. Won't be a straight straight fit but close to it.
We can supply extensions and plugs as well.
Comes in 550, 725 and 1000cc variants.
- Brendan
How much are the 550cc and the 725cc's including plugs and extentions? Cheers
Full set of 6 with the lot;
550cc - $600
725cc - $640
  • 3 weeks later...
After a price on a set of injectors to suit rb25det neo around the 600cc mark? What's brands do you have aswell?
Hey!
We stock a few brands incl. VDO, Sard and BOSCH.
I would go with a set of BOSCH 725cc injectors with extensions and plugs.
These are flow matched and E85 compatible, full set would be $640 incl. delivery.
Let me know,
Brendan
(VM)
  • 1 month later...
Some new injectors have just come in... so a lot are now at clearance rates to make way!
Just ask and we'll let you know of current pricing.
NEW unmodified 1150cc BOSCH injectors now available!
Available to suit 11mm or 14mm fuel rails
Hi
I'm after a price on some Bosch 2000cc or 2200cc for r33 Gtr
Hey!
I would go with the 2200cc short injectors from BOSCH.
Price on a set of 6x with plugs and extensions to suit would be $840 for the set with delivery.
Let me know,
Brendan
(VM)
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
