Car is up for expressions of interest
Its a 1995 R33 GTS RB25de Manual with 143,063km on the clock.
Plenty of work has been done and everything is in good condition. I have the original import papers, recipts for most of the purchaces and modifications done to the car. This car has been very well looked after by myself over the last 2 years. Ive only put 98 fuel into it and have serviced it every 5,000km
Will put some pictures up in the coming few days.
Read and look at some pictures and video footage in this build thread.
http://www.skylinesaustralia.com/forums/topic/348709-r33-gts-build/
Car is located in Brisbane QLD
EOI: 10k
Interior
Sparco chrome pedals
Blue ac/speedo lights
Auto meter 3 Gauge cluster - a/f ratio, Oil/water temp
Nismo shifter
Cusco roll cage sprayed flat black
Replica bride low max
Engine Bay
Apexi pod filter
Custom aluminum intake piping
Custom CAI
Full exhaust system - DK&E extractors, 150 cell high flow cat, 2.5" piping, Varex cannon muffler
Apexi strut bar
Custom hand brake and shifter boots
NPC Exedy heavy duty clutch - 125,417 - Oil change
Clutch master cylinder rebuild - 128,000
PWR 21 row oil cooler
Oil filter relocation kit + cooler lines
Platnium spark plugs
Exterior
Nismo clear side indicators
Black Driftek rims 17x8 +34
Blue lock nuts
6000k HID lights
Series 2 rear spoiler
s2 front grill
White parker lights and licence plate
Mspec front bar
Guards rolled professionally (no hammers)
Other
GTS-T rear sway bar
GTR adjustable rear strut bar
RDA Front and back slotted rotors - 123,000
A1RN QFM brake pads front and back - 123,000
Hel braided brake lines (blue) - 123,000
5 stud R33 GTS-T - 123,000
R33 GTST 4 pot calipers 2 pot back
Diff re-shim - 127,000 - Penrite Limited Slip diff fluid
Bosch battery
Adjustable arms
- Front Caster
- Rear Toe
- Rear Camber
Tein RE coilovers - DQNo5-1CBC2 - ECR33-R-1001
Federal 235/45/17 595 SS
Brand new rear hub bearings
Personialised plates: 33FTW
Bad points on the car would have to be a few body imperfections. Having a small bit of rust around the bottom left rear windscreen and along the middle right of the windscreen as well. Im guessing from a crappy install by a previous owner.
Car has an exhaust defect on it at the moment which I am sorting out before sale. Will be adding an extra muffler to the system to quieten it down.
Feel free to ask any questions. I only want genuine buyers.
Regretful sale but I must due to a change in living conditions.
0434813979 - Joel
Added an extra hotdog resonator to the exhaust system today which has quietened it down a bit and has a very nice note to it.
Car is also fully mod plated for everything that has been done to it so no need to worry about legality's P PLATE friendly.
Hmmm interesting project..
For all the gravel heads like me, the R33 GTS is actually homologated with CAMS, so you can legally rally this thing as a PRC rally car. Would be sweet to have a 9000RPM RB throwing rocks in the forest. Just need to pull out another 2-300kg, and work out how to fit 15" rims over the brakes, and a rallying we will go :yes:
I presume the cage is bolt in? Does it have harnesses?
I did get it down to 1230kg before the cage (if I remember correctly) Yes the cage is bolt in, I haven't got any pictures with it in but I will put some up later on. Have always been meaning to get a harness but never got around to it.
  • 3 weeks later...
    • yeah, there's a country that recently started importing Skylines, I blame them.
