Alright so I got a set of ID 1000's from Tu Speed and I was told that they fit in the std GTR fuel rail but since trying them I have found out that they are 11mm not 10mm.
So my question is, is there a 10mm adaptor available for these injectors that anyone is aware of, or will I be required to get an aftermarket fuel rail? Obviously prepared to get what is necessary but I'd much prefer to use the std rail.
This is the 11mm adapter that was supplied.
https://www.sau.com.au/forums/topic/396885-can-id-1000s-fit-std-gtr-rail/
  • Replies 69
Posted Images
Ok i didn't measure the std rail I just assumed that's what it was. We did measure the adapter though with digital verniers and it is 11mm and definitely does not fit a std rail, does fit a Trust rail though.
Had the same issue with a set of id2000 and a tomei rail to fix it i machined off a small amount from adaptor to suit the rail was quite annoying was hoping for a plug and play fit..
Lube and some muscle and muscle and muscle
Did you use the 11mm adapter the same as I shown in first post?
The ones I have there is no way they are going to fit with or without lube.
Is there any difference in rail size between 32/33/34 maybe?
Just got this email from Tu Speed:
I've had the following email back from the guys at Injector Dynamics -
The stock rails are 10.5mm, it's the only engine that uses a 10.5mm top. We don't offer a 10.5mm top, the rail will have to be machined to 11mm or replaced with an aftermarket 11mm rail.
Yes they do fit. I have id1000's in standard gtr fuel rail.
You sure your rail isn't machined then?
i had to get adapters. I have a greddy rail, but the previous injectors were Nismo 600's, which i would assume would fit a standard rail?
Assuming the previous injectors were for a 'standard size' that means my greddy rail is also 'standard size', ergo ID's don't fit standard rails. I got some adapters from an online place in Melb, wasn't much, $30-$40 i think, tuff car parts or something like that? Just make sure when you install there aren't any metal filings still hanging around...
i didn't want to machine the rail.
is there a Trader on here for these? seem best price is shipped direct from US. CRD are $1200
Fark, I can get matched ev14 1000's for $600 a set locally with warranty...
I can machine the adapter too if anyone needs it done. I cant believe they wont make GTR 10.5mm adapters.
Give Tuspeed a buzz they supplied mine for $760 delivered.
What would a set of adapters cost mate I'd be pretty keen on a set if the quality is good.
I would just buy a set and machine the outside down a little for it to fit, is it the o ring that wont go in or the alloy?
Better that its anodized on the inside, otherwise I would make them myself out of stainless. Its not much material but it could take a while to turn them up. How much are the adapters anyway?
exactly, just got a full set for my nugget from tuff car parts for a killer price.
nothing is the same as Injector Dynamics - yes they all start off as the same base model Bosch but ID do their own thing to them and then sell them, whether or not that's marketing or an actual improvement in the injector itself...who knows, but enough people who know what they're talking about comment on ID's specifically, so i would like to think there is something to say of the process ID undertake.
The price isn't that much different, just get the ID's. And don't let anyone sell you the bog standard ones and say they're ID's, they're not. It sounds stupid to point out but only ID injectors are ID Injectors :D
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
