  • Replies 69
Posted Images
nothing is the same as Injector Dynamics - yes they all start off as the same base model Bosch but ID do their own thing to them and then sell them, whether or not that's marketing or an actual improvement in the injector itself...who knows, but enough people who know what they're talking about comment on ID's specifically, so i would like to think there is something to say of the process ID undertake.
The price isn't that much different, just get the ID's. And don't let anyone sell you the bog standard ones and say they're ID's, they're not. It sounds stupid to point out but only ID injectors are ID Injectors :D
Don't be so sure, they just machine the end, flow match them apparently and ship them out in sets. From the factory the Bosch ev14's are matched very well, no point importing ID's imo when the same product locally is so cheap and comes with warranty.
Injectors online will send you a set of ev14's, they machine the tip onsite, I think so it clears multiple plenum installs. No issues with them here...
My ID 2000's will be here tomorrow. So i will let u know if they fit or not.
When Sir Rb was swappinghis injectors at my shop on saturday his 600cc injectors wouldnt fit in his stock rail either. But then we used the stock o rings and they fit perfectly. Basically there was too much "crush" on the oring and couldnt push en in
700cc sard injectors :P
and yep ended up changing all the o rings to the standard ones as they wouldnt fit in, but thats all good now and sorted
never thought the 1000's or 2000's fit the standard rail...we shall find out soon from Jez
Dont tell me that man. Maybe i should get em flow tested first
I could've been very unlucky fingers crossed you'll be fine. Got Godzilla to flow test them and from memory at low duty cycle the dud was 7 or 8% out. :(
Edited by Ryan1200
Yavuz, Steve and I were talking about this exact topic. The short story was;
ID's flow very very close to one another.
The 'standard' items need some mixing and matching.
Came straight from the horses mouth!
That's the first I have heard of issues, 8% would be a factory defect and certainly be replaced anyway but most people wouldn't check and shouldn't be expected to. Were they bought through the Aus distributor or off ebay?
I don't particularly like the 2000's design but the 1000's have been great in my case and the other few cars I have seen running them. Same with the 750's. I may ask for a flow test on the next set I get as the supplier guarantees less than 2%, I figured there would be more variation in the fuel pressure to them than that 2% would affect on afr's.
2% is still a fair bit. Aslong as u can position that injector in cyl 1 or trim the inj per cylinder egt's. But thats a pain in the but on rb26's. Its near impossible to get temps from them
What's wrong with the 2000's design?
There is a big plate at the end, with jellybean gaps for the spray to come out, it doesn't look like any nozzle I have seen. The supplier mentioned there would be no warranty with them if I ran e85 as the rubber o ring wasn't compatible and also that they were primarily a natural gas injector. As they would certainly be in contact with Bosch I took them at their word and stayed with the 1000's.
I will probably just run 12 x 1000cc injectors and make a custom plenum if I ever get around to building the VQ35det.
Mine seem to work just fine.
Idle and drive better than my old Sard 800's and after 18 months of E 85 use, look just like new.
Even watching the wideband on constant load/throttle, the 2000's AFR's don't 'jump around' anywhere near as much as the old Sards.
I was put off by what they said, obviously. Especially losing the warranty.
I had heard of all the good reviews on them from here, including yours Paul, and other searches I had done on them but at the end of the day you would usually go with what the professional in the injector trade suggests for your application.
Did you get yours flow tested Paul? I would be very interested to see the spray pattern, especially at lower pressures. Perhaps that's another thing I can ask the distributor to help me with.
No I haven't. Maybe I should seeing that they are out of the car.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
