Hi All,
Just hoping for some input. We are currently doing a RB26/30 conversion for my BNR34 and we didn't want to run a sump adaptor so an extra piece was welded on and machined flat. Has anyone done this conversion or know anyone who has?
Looking for some input, will it work? Or will I run in to more problems? Cheers! Pictures below:
Before welded:
After welded:
Both Sides welded:
Machined:
Edited by destrukshn
https://www.sau.com.au/forums/topic/396893-bnr34-rb2630-conversion/
Good luck with that! I have a steel sump adapter but will be interested to know if yours works out. Can't you just bolt the sump on without a gasket to see how it looks?
What's the plan at each end?
It is not a problem of fitting the sump, it will fit the sump as it was already put on and those pieces were cut to fit the RB26 sump. We just need to tap the holes.
It's about the strength, will it crack? Just curious to see if anyone else has attempted this modification to avoid a sump adaptor?
  • Like 1
did you weld the top too for strength, I would also try and weld some tabs on top to help.
The idea is good but you are trying to weld to cast, was something I thought of doing but was advised against and brought the platinum adapter instead, so am very interested how this turns out
Well it was welded both on top and the bottom for strength. Yeah i was told that youre trying weld on to cast it is hard but apparently with the right welding tools you should be able to do it. We'll see if it is strong enough! :)
Whats the plan for the oil pickup, its tight enough with an adapter plate
Oilpickup? It will use the same spot as the RB26 dipstick. :)
I would have thought the only approach to do this would have been to build up the sides of the block gradually, so that discimilar metal thermal expansion variations are minimised. Thereby minimising the creation of stresses in the added material. It would have to be oven heated to do the welding to do this as well.
It doesn't look like there is a taper on the mild steel plate where it was welded to the block too. A thicker fillet weld between the block and the plate will increase the chances of this working if you couldn't get the metalurgy 100% correct. Welding it with a lot of current/heat to get complete penetration into the join might complete the weld, but it creates stresses all through the cast and added materials.
Weather it holds up is anyone's guess. You won't know till you try it.
what material is the extra piece?
What material weld was it?
If neither are cast iron it won't work
How was it welded?
If an oven was not used then it will crack and split
Though A for effort and trying something different
Not too sure of the exact material, but i am guessing it was some sort of steel.
Well it has been machined and hasnt cracked yet so it looks a bit promising. As it retains a few original holes on the RB30 from the RB26 Sump, will tap out using larger studs to ensure it doesn't move.
Whats the reason for not using an adaptor plate? Sounds like an awful lot of effort for something that would worth with a plate?
Well the reason for not using it was probably due to extra 10mm which person working on it didnt want for sump adaptor. Possible oil peaks too.. Well cutting was done in house, welding was done free & machining was done free. We'll see if it works otherwise if it cracks, can always take motor out and fix it! :)
Haha yeah guess we'll just have to wait and see once it is done and if it holds up! Thanks for the input!
I like it! Nearly looks like an RB26.
The only suggestion I'd make would make would be to haven an align bore done on the mains. Shave 1 thou off your cradle, install your main studs, and then re-align bore the main bearing saddles to make sure everything is straight. Then do the rest of your block machining.
It does look like an RB26 indeed, just letting everyone know the welds are so hard that our drill is having problems drilling the holes and it is getting done by someone external and not in-house!
There is no reason to align bore done on the mains. There is nothing wrong with the mains and so there is no need to realign them. It is factory aligned.
heat from welding may have distorted the block, so if there is the slightest twist then the tunnel may not be in line, which is why a line bore/ hone is done, if it is not, and the alignment is out then the crank may rotate at an awkward angle and force it to flex and vibrate, and or seize
material hardness effecting the drilling... to make it easier get a drill bit guage and then sharpen the drill head to match the angle recommended for the material your drilling into
Heating was only done on the top of the block, the whole block wasnt heated just to weld the sump extension pieces on and so there is no twist in the tunnel. It is definitely aligned. Work is done by professionals and there is no need to worry about it being out of alignment, but thanks for the input :)
The holes are drilled now, will update with pictures once short motor has been assembled!
You are crazy... as if you would not go through the trouble just to be 100% sure. I know plenty of "professionals".
+1
I've not measured a standard block and seen all the mains measure up the same, let alone a welded one. For the extra few hundred dollars its worth the piece of mind. Personally I hate the idea of pulling an engine out of a car to fix something I could have done better if I'd just paid a tiny bit more.
While you might 'get away' with it in a lowish power situation combined with big 2.8+ thou clearences, why would you set an engine up like that if you can do better. Especially in a GTR.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
