Hi everyone
So i have just bought a r33 4 door of a close mate and not so long ago he had a bigger fuel pump put in as an " i owe you job " and ever since every now and then you will be able to hear the fuel pump whirring fairly loudly (i can hear it over the engine) although i usually hear it once i start slowing down and the engine is quiter.
Every now and then it will cause the pump to surge but usually you wouldnt hear the fuel pump or have it surge and it would only make the whirring noise and surge when i was running on a low tank of fuel but i have noticed it does it every now and then regardless if how much fuel is in the tank.
Does anyone know what i can do to fix this?
Should i just get a stock fuel pump?
Any help is greatly appreciated
Ps1Locybe
https://www.sau.com.au/forums/topic/396933-fuel-pump-help/
I actually ment to write:
It doesn't always make the sound or surge it usually did it on a low tank but now its doing it randomly regardless of howmuch fuel is in the tank.
P.S my mate said the fuel pump was getting air pockets in the lines causing it to surge or something.
Once again any help is greatly appreciated
https://www.sau.com.au/forums/topic/396933-fuel-pump-help/#findComment-6303327
  • 2 months later...
It will even make this whirring sound when i am on over half a tank of fuel, i am beginning to think the bigger fuel pump is moving uneeded fuel around causing it to heat up and thats when i can hear the pump, it also has trouble starting up sometimes, i have found that if i turn the key and listen for the fuel pump and try start the car before the fuel pump finished pumping fuel it will start fine but if it finishes pumping then i attempt to start it will struggle and i usually need to give it some gas to help it start, which i shouldn't being an automatic transmission.
Im also thinking a fuel pressure regulator might fix this problem but what us everyones thoughts?
Really need some help on this guys?
Ps1Locybe
https://www.sau.com.au/forums/topic/396933-fuel-pump-help/#findComment-6404406
I don't think i have a fuel pressure regulator that im aware of? I ment should i get one?
Sorry im not very mechanicly minded and i bought this car of a friend not long ago so i dont have a very detailed understanding of what happened with the fuel pump, when i asked him in a message he replied:
aw it's like equivalent to a Bosch 040 or a 044 some thin like that it's a decent one.
So i guess im going to have to find out for sure exactly what pump it is and if its properly wired to the battery first?
What can i do if i cant find out solud details?
https://www.sau.com.au/forums/topic/396933-fuel-pump-help/#findComment-6406037
We need more information to help you, what pump is it? Has it been wired to battery voltage like all aftermarket pumps should be?
noob question but why do aftermarket pumps require this? and is it applicable to Tomei and nismo pumps too?
https://www.sau.com.au/forums/topic/396933-fuel-pump-help/#findComment-6406390
Factory setup switches between 6V and 12V, 6V at idle/low load and 12V for higher load. Aftermarket pumps don't like 6V, and don't perform very well at 12V (infact might be worse than the factory pump). It's only when aftermarket pumps are running at alternator voltage will they deliver what they advertise (255lph for walbro pumps etc)
https://www.sau.com.au/forums/topic/396933-fuel-pump-help/#findComment-6406491
Thanks for the info, I was intending to upgrade my stock pump with a DW200 it has voltage rating of 6-18v do you think it would still need the wiring mod?
http://www.deatschwerks.com/dw200-fuel-pump-tech/
sorry for the thread-jack, Paul hope you're finding the info useful too.
https://www.sau.com.au/forums/topic/396933-fuel-pump-help/#findComment-6406561
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
