Hi,
Had my GT3076 installed yesterday and the car wont idle after driving. Drove fine before the switch. Could it be tune related? Previously had a PFC tuned for a FMIC 3" exhaust, stock afm and R34 NEO turbo. only things to change are some of the plumbing from turbo to cooler, intake pipe and obviously the turbo. If I start it cold it idles fine. Once i drive it and pull up in traffic it just stalls and takes about a minute of me trying to gently feather the throttle til it idles. Any help please?
https://www.sau.com.au/forums/topic/397005-hard-to-idle-after-turbo-install/
  • Replies 58
I hate to say it, but what the hell has the tune (or lack thereof) got to do with hot idle?
We're talking about no revs and no load and so the turbo has no effect on the idle. Things like changing the BOV configuration and so on might contribute, but he could have strapped a T88 on there and you'd still expect it to hot idle.
And he could nurse the car along with little or no boost to drive it home and again the turbo would have no impact on the way the car drives, and even if he made a little boost here and there, the bloody car has an AFM so it's quite likely that it could handle it just fine without turning the plugs into charcoal crayons.
My vote is also on hoses or similar installation whoopsies.
Its a GFB bov and its been on there for years. it drove fine to get it home in the fact it was smooth and could change gears etc but as soon as the clutch went in it and the revs dropped at a set of lights will stall. The gear changes dont see the revs drop enough so thats why it seemed to drive if that makes sense. Even sometimes on decel it can get a bit shuddery. I dont intend on driving it anymore until it is tuned I just dont want an already expensive tune to turn into an expensive fix and tune so was just looking for an answer in case it was something I could do and then get it tuned.
Edited by FordyR31
Do you guys do a risk analysis before you take a dump? Sorry, should go back a step; Do you guys do a risk analysis before you eat something spicy?
Nah, sorry mate, can't put it on the dyno, not safe to drive it onto the rollers....
Idle issues; check vac lines, afm may be a bit touchy if you have a short metal intake pipe or an atmo BOV so the tune it may need a touch up in that area possibly combined with adjusting the idle screw.
The bov is plumbed back permantly on one side and i have tried with both the atmo attachment and the plug in so it was completely recirculating. Again this is no change to how its been for the past 5 years. yes it now has a steel 3" intake pipe but all the plugs are the same for the bov and breather etc. its just a metal copy of it pretty much to retain the stock airbox until i get another one made and afm position.
Is the IAC valve plugged in?
We need more information on what has been done.
For all we know, you could have bolted a bigger turbo, cams, injectors, blow through super charger, and hooked up a bottle of NOS.
More information please, not just dribble it in as we need it.
I have already mentioned whats been changed.
before issues:
S2 RB25DET
Power FC tuned
R34 NEO turbo
Splitfires
3" exhaust
FMIC
Recirculating GFB bov
Stock intake and airbox
They are all the mods that were done and it was running perfectly.
Changed the turbo
Modded the intercooler pipe to suit
steel intake pipe with all hoses attached as if it were the factory one.
The tune could be the issue for the fact that the turbo could be a bigger restriction on the intake side hence snuffing the engine because the turbo is trying to effectively stall and the engine can't breath enough through the intake hence why it stalls. Would be unlikely but possible.
As said before, it sounds more like vac lines of some sort allowing it to gain air that it doesn't relise it has hence leaning out and stalling. Check ALL piping (before turbo, after turbo and even manifold, even if you haven't been there as you could have bumped it off) as even a leak from a clamp not been done up can suck air through which the engine doesn't know it has. It will idle when cold due to the engine automatically enriching the engine till it gets to temp. Effectively counter acting the air in the system it doesn't even know about. When it gets to temp it leans back out and stalls for been too lean.
You could have gotten oil from the filter if its an oil based filter onto the air flow meter even, or simply it could have gotten dirty while installing the turbo as you only need to get a little bit of crap on it to make dramas. For this one, get some contact cleaner (yes contact cleaner not brake clean or anything else) from super cheap/ autobarn/ etc for a couple of bucks and clean the fine wire in the center of the airflow meter where the air passes over.
Give that ago to start with.
Matt
Youve stuffed the plugs because your driving a car tuned for a 1hp turbo which now has a 500hp turbo.
The ecu measures load by AFM voltage, I imagine that the AFM voltage would be a little higher when your cruising around (using some throttle) than when using the tiny turbo.
Get it to a tuner ASAP as the extra fuel would be washing down the bores and potentially FK'ing the motor.
I don't understand this???
AFM does have an effect but it only measures the amount of air passing over it.
The amount of air passing over it effectively cools the wire causing the wire to have more resistance in which alters the voltage giving you a reading.
The input voltage never changes. It is set to 5 volts from memory and is so that even if there is low power, spikes, etc it will still read effectively.
Engine load on the other hand is measured by a number of factors. These include tps, road speed, boost/vac, inlet temps,O2 sensor readings, etc.
In my opinion, by changing the turbo it has done nothing to the lower part of the map. This is because the AFM is still reading the amount of air coming in as nothing has changed that fact that it is still cooled by the amount of air coming in. Therefore if the turbo was changed and the air increased or decreased it should in theory measure that anyway and adjust to compensate. If it was adding too much fuel it would be picking up that it is doing so via the O2 sensor and still it would adjust to suit.
I do however agree that the engine should be tuned for the new turbo asap as the amount of air the turbo would flow at higher rpm compared to the older turbo could effectively have the afm run out of room to measure therefore leaning the engine out causing detonation or depending on the safety setups in place on the power fc could richen the A/F mixture causing it to wash bores.
If this is incorrect please explain to me as more info can never hurt :)
Another thing to check is to make sure you haven't damaged the O2 sensor as well, as this is used under cruise and no load situations (idle) as a closed loop system and is also disregarded during warm up.
Yes, the AFM has 5v in and the element measures flow by vibrations in the passing air and outputs a voltage. The ECU reads that as airflow and plots a certain point on its mapping with that data along with other data.
To say it would little impact on mixtures is ridiculous. Thats like saying boosting a stock R33 cant possibly make it hit R&R................... Wrong right? Yeap.
The points that are likely to be screwing his mixtures badly are the cruise areas of the map like I said. Between 3000 and 4000 rpm where the turbo IS pumping a fair volume but is not yet 'boosting'. You have to agree that the stock turbo would not suck an identical volume to a 3076R at that level, and its doing a little more than idling along (consider your in 3rd gear at 40kmh and start trying to chuff along to 60kmh). Thats going to be a big difference in flow from the compressor between the two, and subsequently a big difference in the resultant map trace.
I hope Ive explained it clearly enough for you. My theory is that his plugs are fouled. Remember that his comments were, it ran like shit after I drove it a while. Not, my car ran like shit ever since I installed the new turbo.
Wrong wrong wrong.
Nissan AFM is a hot wire type, not a vortex counting type (like Mitsu). AFM is THE thing that determines engine load. What the AFM says the load is, that's the load. Doesn't matter how you get that load - by hanging the AFM off a big motor, or hanging it off a small motor with a little turbo working hard or a big turbo hardly working. The load is the measured air quantity.
THE SIZE OF THE TURBO WILL HAVE NO SERIOUS EFFECT ON THE MEASURED LOAD OF AN ENGINE THAT IS JUST BEING DRIVEN AROUND GENTLY. It's only when you get serious revs and boost happening that the differences in exactly what revs which airflows happen at start to affect a tune.
As I said previously, he could have bolted a T88 to the engine and it should not affect how it idles, and it should not affect low load driveability either. In fact, you could try to drive it quite hard, and as long as the previous tune covered the low load (ie, no boost) high rev portions of the map properly, it would probably be quite fine then as well.
Drive it around all you want, under light loads your not going to wash down the bores and destroy your engine, what a joke! Whilst i wouldnt reccomend it, 90% of the time it'll be fine to thrash on low boost too, aslong as the previous tune isnt miles out.
It sounds like a leak somewhere, check every bit of the intake piping for leaks and if you cant find any you could try pressurising the intake and using some soapy water on the joins. Otherwise if your certain its not leaking, try cleaning the afm.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
