Did a search and couldn't find anything...
I can't seem to get the front defog mode to work on the climate control. Everything else seems to work fine, just when I push that button nothing happens. I know it used to work a week or so ago and I doubt it could be a fuse as it's just the one button not the whole unit.
I did run a diagnostic and the light for the button works and also the motor/flap works when I do the vent test as I can feel air go to the top vents, but just doesn't work when I push that button.
Anyone know what's going on or if I'm going to have to pull the unit out and fiddle? :/
https://www.sau.com.au/forums/topic/397014-r32-ac-front-defog/
Ok after driving for around 20 minutes last night I tried the button and it works again -_- and worked multiple times. Didn't work when I first got in the car though so I left it until around 20 minutes later.
May just be a dry solder where the switch is soldered to the board. Will test again when I have to go somewhere.
