Hi all i am just gauging the interest in the my motor built by paul from red r racing. The motor has less than 8000km on it and was tuned by Guilt toy ( Anthony ) as i am selling my gtr and getting no where and i am looking into dropping a stock motor back in it all selling it stock for $15000. The car is located in Newcastle also
This will be a complete drop in package with Power Fc computer to suit early model r32 gtr, z32 afms ect ready to go. The current tune makes 430hp at the wheels with a very restrictive exhaust and stock intake system this set up is good for 380kw.
The motor package consists of
r34 gtr crank
CP 40 tho pistons and eagle rods
ARP big engine studs
ACL big end and main bearings
Crank collor
N1 Water pump
HKS oil pump with thrust extension sump
Oil restrictor in the head
Nitto head gasket
Tomei type B cams and valve springs and retainers
Tomei adjustable cam gears
Ross 1000hp balancer
2860-5 turbos garret actuators
stainless steel dump pipes
1000cc HKS injectors
z32 AFMs
Spit fire coil packs
gates timing belt
Jim berry single plate clutch 4400lb clamping pressure
Recoated covers in wrinkle coat black
This package would cost anyone to build $18 000 - $20 000 with labor and tune at a good workshop not to mention the wait time and having to run the engine in as well.
I am asking around $12 000 but throw some offers up
There is plenty more photos to
Feel free to ring me on 0434108477 or pm me for more information
Cheers Scott
bump anyone interested in a fresh run in motor that saves the hassles of getting one built and sourcing all the parts
Would you part with enough interest?
Maybe mate its a pain in the ass for me really if i dont have confirmed buyers for everything. I am just after a nice and easy sale where someone can come and pick up the hole package. But feel free to throw up a offer on what you would like.
crank collar, with R34 crank. why ????.
I dont know the exact reason for the crank collar on the r34 long nose crank i'd have to ask paul i just remember him saying something about it i can ask him for calcification if you like ??
Thanks for the intrest guys pms have been sent however for the record i wont be stripping to a short motor long motor cost is $8000 ono and there will be a video of the motor running and compression test up soon if anyone wants to see the motor is still in the car driving
cheers
  • 2 months later...
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
