Hey,
I have recently got a r34 running great expect for a couple days ago, basically the idle when cold is at about 1100rpm and sounds very rough it use to sit around 1500rpm.
When i turn it on when its cold it will slowly creeps to 1100(used to hit 1500 pretty fast) and feel abit rough till warms up to temp any ideas on what it might be or what i would need to do to diagnosis it?
i have a feeling maybe it has something to do with the fuel? cause the first time it did this it chocked when i went to start it, then turned on if that has anything to do with it :s
any help would be great :) thanks
https://www.sau.com.au/forums/topic/397061-r34-cold-idle-low/
your IAC might be full of carbon build up and causing the rough idle, take it apart and give it a good clean and scrub to remove all the black carbon build up inside.
theres a thread in the DIY section on how to remove, clean and reset the idle.
Once you have done that and if it has not fixed the issue, give your Idle screw 1/4 to half a turn - only.
I would not expect you to have idle greater than 1 to 1.2 RPM on your tacho. 1500rpm is like an auto choke
Could have been the fuel filter, my RB30 injectors are leaking and its idling on about 900-1k rpm, usually sits on about 1.1k - 1.2k. So if the fuel supply's being cut, it'll obviously do that. Good its fixed though, I've still gotta get round to my injectors ha
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
