With DECA in Shepparton coming up on the 5th of May i was wondering on who was heading up
And if you have always thought about it and never made it this is a great entry level motorsport event.
It also a great way to meet up with others may you only know off the forums.
You dont need to be a SAUvic member or own a 300 kw car.
So if you want to have a bit of fun in you car DO IT.
Ya know ya want to..IMPORT MONSTER- SAUvic DECA
We stay here .......ACCOMMODATION
Volonteers..........OFFICIALS
WayneO
https://www.sau.com.au/forums/topic/397062-deca/
Half keen, just wanna know prices to participate and how big the track is etc? Do i need a CAMS license?
Chris
Most of the information you need is in the above IMPORT MONSTER DECA link
But to give you a bit of info
Cost of entry 85 bucks
You will need one of 2 licences.
AASA licence will cost you 50 bucks and you dont need to be a car club member
CAMS licence will set ya back 95 but you will need to be a member of a CAMS affiliated car club.
The DECA complex in Sheppardon is a is a driver training complex so it not a race track like Sandown and such.
It has a very large skidpan and roads inside the complex. We do motorkhana style events on the skidpad and speed runs on the
roads and its all timed like Tarmac Rally. Its heaps of run.
And since its in Shep and its a long drive to and from a lot of people make the call to stay on the Fri/Sat night to
kick back and have a beer or 4 or 5 and talk about the day and cars and such. We also have some of the SAUnsw come down.
So in general its just a great weekend.
Hope this helped and hope to see you up there.
Wayne.
https://www.sau.com.au/forums/topic/397062-deca/#findComment-6305520
I will be coming again!!! Filled out my form then my niece got to it with a texta so will send it off Tuesday now.
Recommend anyone to go guys. I went in my stock 33gtst and had a ball.
Good to see ya coming up again Rhys.
see you up there.
https://www.sau.com.au/forums/topic/397062-deca/#findComment-6306200
Easily the most enjoyable car weekend away.
A couple of us come to the ones that don't clash with NSW events any chance we get.
The guys and girls who run it are fkn legends, don't be afraid to ask anything if you're not sure or if it's your first time.
It's great also in that the stress on the car is minimal (one lap at a time) so that's nothing to worry about, the speeds you do are not silly, you don't need big power to be quick at this-so many times we see the guys with commonly considered "slow" NA cars do heaps better than built GTR's.
It's only $85. Give it a go. Anyone who's been before will agree its great fun and you'll also regret not going to previous ones because they're just addictive.
Keep up the great work organizers and volunteers.
https://www.sau.com.au/forums/topic/397062-deca/#findComment-6307034
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
    • Yeah, but "restomod" implies Singer and things like it, which implies drug money / trust fund maturity.
