hi
i am new to this forum then i hope ask my question in right section
i want swap an RB26 on my cefy . it has already RB24 and i want to know if i can use my RB24 trans with RB26 clutch and flywheel and sump from RB24 for this swap ?
want to run the stock motor with stock turbos and only 10 psi of boost i think my trans will handle the power if it bolts right.
my engine is from a 90 skyline then it is push type as my current clutch act
Your gearbox will bolt straight up, no worries. You'll have a standard RB20/non-turboRB25 gearbox on at the moment. They're fairly weak compared to RB25 gearboxes, but as long as you're not doing neutral drops and clutch kicks all day, and trying to quick shift every gear change, it'll hold up fine.
Clutch and flywheel no problems. Just use whatever is on the 26.
The flywheels are all the same, 9.8kg. The clutches will be the same, but the GTR pressure plate is a bit heavier.
The oil sump will be a problem.
24 sump won't bolt up to the RB26.
You can either cut and weld the 26 sump to suit RWD, or you can buy a RWD RB26 sump in from Japan. It'd probably be cheaper to get the 26 sump welded up, but look at both options first.
Engine mounts, not sure.
If the RB26DETT ones dont slot into the crossmember, then take the mounts, brackets and bolts off the RB24. Just a case of what fits, not what suits
The diff is a bit of a pain in the ass.
The diff will fit the cradle, but you'll need to use the drive shafts and hubs (which are stronger than your current ones), you'll need to change the nose on the diff as well, to suit your current tail shaft (unless you have an AWD A31 ??)
Best bet = take out the diff centre from the GTR, put that into your current diff housing. Use the GTR drive shafts, drive shaft flanges, hubs, etc.
Yep fair enough , gtr diff is 6 bolt axle shaft , all spaced apart , im pretty sure you need the full axle and hub to make it fit . I can vaguely recall a friend attempting it and failed , ended up buying a s13 lsd in 4.36 as it bolted up to the axles (3X2 bolts )
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
