hi
i am new to this forum then i hope ask my question in right section
i want swap an RB26 on my cefy . it has already RB24 and i want to know if i can use my RB24 trans with RB26 clutch and flywheel and sump from RB24 for this swap ?
want to run the stock motor with stock turbos and only 10 psi of boost i think my trans will handle the power if it bolts right.
my engine is from a 90 skyline then it is push type as my current clutch act
Your gearbox will bolt straight up, no worries. You'll have a standard RB20/non-turboRB25 gearbox on at the moment. They're fairly weak compared to RB25 gearboxes, but as long as you're not doing neutral drops and clutch kicks all day, and trying to quick shift every gear change, it'll hold up fine.
Clutch and flywheel no problems. Just use whatever is on the 26.
The flywheels are all the same, 9.8kg. The clutches will be the same, but the GTR pressure plate is a bit heavier.
The oil sump will be a problem.
24 sump won't bolt up to the RB26.
You can either cut and weld the 26 sump to suit RWD, or you can buy a RWD RB26 sump in from Japan. It'd probably be cheaper to get the 26 sump welded up, but look at both options first.
Engine mounts, not sure.
If the RB26DETT ones dont slot into the crossmember, then take the mounts, brackets and bolts off the RB24. Just a case of what fits, not what suits
The diff is a bit of a pain in the ass.
The diff will fit the cradle, but you'll need to use the drive shafts and hubs (which are stronger than your current ones), you'll need to change the nose on the diff as well, to suit your current tail shaft (unless you have an AWD A31 ??)
Best bet = take out the diff centre from the GTR, put that into your current diff housing. Use the GTR drive shafts, drive shaft flanges, hubs, etc.
Yep fair enough , gtr diff is 6 bolt axle shaft , all spaced apart , im pretty sure you need the full axle and hub to make it fit . I can vaguely recall a friend attempting it and failed , ended up buying a s13 lsd in 4.36 as it bolted up to the axles (3X2 bolts )
    • Can't see that being a thing.
    • My fob has never worked, I once attempted to follow the procedure to re-key it, (I have other fobs for the car alarm thing in there). I actually have three of them. Do aftermarket alarms take over the pairing mechanism for central locking? Or do they piggyback off it? I suppose it depends on the system, right? I have four sets of keys/keyfobs. One definitely works, one I think works, one definitely doesn't work, and I have the OEM one that has never worked :p. Is this fixable/workable/whatever? I mean I know it's beyond "just clean it" but how *do* they get synced up?
    • It's actually a really weird comparison... the MX5 is on another level and I kinda question this comparison at all. It'd be closer to compare it to a GTI/Golf/Hatch anything that kicks around. NC MX5 with a turbo has the right to go up with and beat the FD RX7 or 180SX or any other JDM hero car. That's the comparison that would really ruffle feathers.
    • @MBS206 you need more shed in your life... What sort of car is your mates race car?  Hopefully he returns the favour when you're ready to get cracking on yours! None of my mates are into cars so I don't have to worry about that as a distraction thankfully.  I have enough other distractions so I don't need that one too!  Between working 6 days a week (5 1/2 really so 55 hours or so per week), both kids have basketball almost every week night (including Friday night in Melbourne - 2 hours away), my daughter plays netball as well, my sons footy has started now and I coach his under 14's side as well as I'm on the Footy club committee this year, I ride motorbikes every spare Sunday I can find, plus trying to be some sort of a husband.  Life is a busy little exercise at the moment!  I wish there were 8 or 9 days in a week sometimes!
    • Ha ha, that is very true!  I'm too scared to leave it in the position though, it tingles my balls seeing it like that!
