hey guys pretty much as the topic states started gettin a weird clunk noise when i go over a bum from the from left (passenger) side no idea what it is also when i went to undo the wheels to have a look what the problem could be i noticed that when i put the ratchet on to undo the wheel i could actually move the wheel a bit (from left to right) with a bit of force really got no idea what it could be anyone got any ideas?
Get the wheel off & keep looking, with some leverage, something is really faarkt. But you already know that.
Cheers GW :miner:
yeh i was thinkin something along the lines of ball joints or maybe tie rod ... question is how to check it ? or should i just take it to a mechanic?
You said "when i put the ratchet on to undo the wheel i could actually move the wheel a bit (from left to right) with a bit of force"
I said "Get the wheel off & keep looking, with some leverage".
What I mean is get further in, front end on axle stands, wheels chocked, car in gear, hand brake on, offending wheel off, head down, crowbar/piece of pipe/jemmy bar/tyre lever/something that you can work the wheel hub & linkages up down side to side with while you have a good clear view of what is going on or trying to come off, is loose or rooted, whatever. Could be lucky & have some nuts/bolts that just need tightening up. After you have determined that the strut is not about to colapse or some other nightmare, then arrange taking it to a mechanic if you cannot fix it yourself.
My other 2c.
GW :miner:
...i could actually move the wheel a bit (from left to right) with a bit of force really got no idea what it could be anyone got any ideas?
That would usually be a wheel bearing. Try moving the wheel top to bottom - if you get the same sort of movement, then it will almost certainly be the wheel bearing. Might just need a bit of grease and a tighten up. Might be shot.
Yeah. Usually if it's making a clunking noise, or some really weird grinding combined with squeaking sound when traveling over speed bumps, or just a general imperfection in the road, it will most likely be what the guys above outlined. Although, you only really notice it at slow speeds and the faster you go, you won't be able to hear it.
Get in there and see what it could be, if it's fixable... do it yourself or if you're not confident, just get a Mechanic to look at it.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
