A friend recently bought a Ritmo branded PCMCIA to dual Serial port adapter (CC-M66) and I'm going to try to get it to work with XP to run Datalogit .
Struggling with the drivers ATM but thats mainly because I'm not a computer geek . If its a goer it will unchain me from laptops with serial ports and may lead to a way to run Datalogit from Windows 7 .
Has this been done before successfully ?
Cheers A .
Never used one of those but i've used a couple of generic adapters aswell as the ones supplied with datalogit. Out of the 2 datalogit ones 1 was toast, the other worked perfectly and out of the 2 cheapies one works perfectly and the other works sometimes, drops in and out. That was with windows XP though. Aslong as you can get the drivers to work properly it should be fine.
sorry, I don't know about the ritmo adapter....
but I can report i am happily running Datalogit on Win7 64 bit on a brand new HP Probook 6560b which I was surprised to find sitting in a shop with an old fashioned serial port on the back!
PCMCIA is not really a long term help. Laptops don't really come with those slots anymore either. Express Card maybe.... The USB to serial ones are fine. There's 2 main chipset types out there. One tends to be great, the other not so great. If you try one and it works, life's good. If you try one and you can't get it to go, find out what chipset is in it and then get a different adaptor with the other chipset.
Yes thats true , just trying my luck with someone elses gadget . This adapter just happens to be PCMCIA though I'd look for cardbus if buying myself . Will also search for Express card Serial adapters if such a thing exists .
Interesing about running Datalogit from 64 bit Win 7 , that would free up laptop choices for me heaps .
That aside I got my computer person friend to get the gadgets drivers in but forgot to take the serial cable with me .
Always something , cheers A .
Hi Duncan , I looked into those HP 6560bs and they have the serial port standard . I was not aware that any current laptop had them but it is a bonus . Which one did you get and how do you find it overall . Can you PM me on where it came from and what the approximate damage was please .
Cheers and thanks , Adrian .
Hi mate, I picked up the laptop at ht, about 1500 http://www.ht.com.au/list.hts?keyword=6560b.
It's not cheap (although not horribly expensive either), I travel a lot and learned years ago to buy something that is a bit better built. This one seems pretty good.
The fact it had a serial port is what sealed it for me....so much easier dealing with 80s car technology if you have a serial port on board.
Re running on windows 7 64bit, it just would not work. I installed it a couple of times and it kept complaining about not being able to find TABCTL32.OCX
I was running it on a 32bit virtual session in 64bit windows for a while, until I tried running it as "Administrator". Since I changed that setting it has worked fine on win 64bit. Right click on FC-Edit.exe, go to the Compatibility tab, and turn on the Run as Administrator check box at the bottom of the screen.
Thanks Duncan , I've been looking into the Core i7 version of the HP Pro book 6560r and I've seen it going in the the mid 1300s which sounds alright .
It would kill several birds with the one stone because I'd like something more modern than this old Dell D630 Core 2 duo and a real RS232 port would be a huge bonus . It (D630) dual boots 7 and XP and the latter is only there for Datalogit so running it from 32 or preferably 64 bit 7 would simplify things .
Thanks again , cheers Adrian .
Edited by discopotato03
  • 3 weeks later...
Maybe....I stuffed around and tried a million things to get this to work - but here is what I think did the trick.
Create a shortcut to FC-Edit.exe (or just use the start menu one)
Right click and choose Properties
Choose the Compatibility Tab
Select "Run this program as an administrator"
Click OK.
Depending on your UAV settings, you may get a windows warning every time you start the program....but at least it works.
NFI why, but maybe there are smarter PC people on here that can explain it.
Duncan, I'm amused that HP is putting serial ports in again. For a quite a while Toshiba have een the only ones putting a serial port in one of their models, and that is because most electrical engineers require them.
Secondly, ive never had issues with USB to RS232 assorted working with ECUs. Although my current car has an ECU waiting for it that runs a USB connection natively :P
Well after lots of stuffing around by a more computer literate friend I have FC Datalogit running on both laptops and in Win 7 , one 32 and the other 64 bit OSs .
My friend screwed around heaps with VB runtime files and all sorts of OCX crap and didn't have anything nice to say about the people who developed the software .
He doesn't know yet but I think the problems were trying to transfer the FC Edit from one computer to another rather than installing from the original CD . Anyway I got home and installed from CD - and it just worked ...
I noted that the disc has some VB5 files on it but I'll get him to look at these at a later stage .
I assume that if the software runs actually linking to the black box should be no issue .
Anyhow fingers crossed I have a modern laptop running Win7x64 and can still stuff around reliably with EMS software and a real serial port . It doesn't involve running XP in a separate partition , probably couldn't with a SATA drive anyway , or virtual XP like others have done at times .
Cheers A .
    • PRICE  : $1400 LOCATION   : NSW Central Coast FIT  :  All Nissan 350Z type Z33 and Infinity G35 Coupe. See delivery note. Hi, brand new, unused, still in the box.  ($1850.00 is what i paid ) My bad luck !!! I thought my right front  Bilstein was cactus so i bought the ST 's to replace all.  Turns out the right front is fine ( loose mounting after service  by a well known importer of Bilsteins ) So im selling the ST's. They are made by KW ( no intro needed ) . Iam on the Central Coast and im willing to meet up in Sydney metro, within reason and Newcastle.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
